Need Help Removing Wire Harness
Old 02-12-2005, 09:46 PM
The_Reverend
The_Reverend's Avatar
Default Need Help Removing Wire Harness
Ok! Well I spent a few good hours unplugging wires underneath the dashboard because im swaping the entire wiring from one car into another. (long story). Anyways, I got to the point where on the Driverside the wiring actually unplugs right at the firewall, so thats not an issue. However on the Passenger side, everything runs out through the firewall. So which is easier, pulling all the inside wiring out into the engine bay, or pull all the engine bay wiring through the firewall into the car? Or is there somewhere I can disconnect to make this easier? Really need help on this one. Thanks.
