What Next?
What Next?
Hello,
I have a 99 Civic EX with the soch engine I believe. I have installed so far a DC header, aem cold air induction, cat back exhaust. Next I plan on a new intake manifold.
I realize so far that I am getting very minor gains, will the new intake be noticeable? or will I have to go internal, I was thinking of a cam and cam gear. I would just like to get more power in the 3000 to 6000 range.
Am I expecting too much by wanting to get to 160 hp with the soch engine?
Thank You.
Thank You.
Honorary Moderator Alumni
All those bolt ons are a waste of money if you want to"feel" something. Forced induction is the way to go.
To go from the stock 125hp to 160hp (at the crank) you need some serious work. Especially on a SOHC.
Header - 5hp max
Exhaust - 5hp max
Intake - 5hp max
cam gears - 5-10hp max?
cam shaft - 10-15hp
Supercharger - 30-50hp
Turbo 1-really anything your engine can handle
Lightening the car also does wonders. Lighter wheels can take off parastic drag. For every 1lb of rotational mass you remove it's like removing 9lbs static body weight. So going from a 20lb wheel to a 14lb wheel (aka Kosei K1) that's 6lbs per corner=24lbs total. 24lbs*9=216lbs you effectively removed from the body of the car.
Header - 5hp max
Exhaust - 5hp max
Intake - 5hp max
cam shaft - 10-15hp
Autocross Help Page
Autocross Help Page
Turbo will definitely be your most increase in power. If you are not looking to go this hardcore, the bolts will help as well but as everyon has said will not be nearly as dramatic of an increase. PM me with questions or product inquiries. We can help you out with the bolt ons or a turbo if you so desire.
We have been around for a while but new to HAN.
Your Powder Coater
LOVIN the details in this post! :yumyum:
Definitely turbo if you want to get some good gains and have a good platform to improve on in the future.
There are a couple of people on turbod16.com that have daily driven 300whp sohc civics.
Header - 5hp max
Exhaust - 5hp max
Intake - 5hp max
cam shaft - 10-15hp
Header - 5hp max
Exhaust - 5hp max
Intake - 5hp max
cam shaft - 10-15hp
Thanks for replies so far.
Yeah I will definately get some new wheels and tires, Right now I have got stock wheels and firestone tires that really suck!! I get a lot of wheel hop and they are terrible in the rain, but they will have to do untill spring.
On a serious note. You're about the 23423526234th person to ask this question. Please do some searching first.
