Silencing the Accord V6?
I am in the process of silencing my Tundra to give me better stereo sound. I am using a combination of a product called Brown Bread (almost identical to Dynamat but a little thicker, and a LOT cheaper) and some acoustic foam. Photos here:
http://www.gwfweb.com/tundra
The question is, besides the door panels, where would my ’01 v6 benefit the most from this? Rear deck I’m sure. I don’t have subs, so what about the trunk area?
Anyone else done this?
Originally posted by uclaccord
where'd u get brownbread and how d'u put it on
The acoustic foam panel can be purchased at: http://www.amistorefront.com
The BB is self adhesive. Peal and stick. And once it's stuck, it's STUCK! You have to scrape it off.
The foam is applied with a spray adhesive I purchased from the same company and it works great.
A little tip. Put a heavy coat of wax and don't wipe it off where you want to remove the BB. Makes it easy to cut holes and then just peal it off.
