Lambo Doors (92-96)
Old May 18, 2005 | 02:54 AM
Davey2Crazy's Avatar
Davey2Crazy
Default Lambo Doors (92-96)
I recently put sum lambo doors on my 92 Prelude. Not really happy with how they came out as far as the gaps in between the door and fenders and also the dents on the fender from 1 of the bolts on the hinge. I've read around that a few ppl have had this problem so I figure this be the best place to get more info on any1's solutions to this.
Old May 18, 2005 | 05:59 AM
oscarhmoyano's Avatar
oscarhmoyano
Dude i'm really sorry, that doesn't sound good .. i hope you can find a solution .. othetwise go back to stock .. just leave the lambo doors for the exotics .. Nsx's don't got on them (maybe next gen) and they still look exotics ... our Ludes are beautiful without them!
But good luck!
OScar
Old May 18, 2005 | 09:21 AM
cobbcustomz's Avatar
cobbcustomz
what kit do you have? I have a more noticeable gap between the door/fender. Nothing horrible but still larger then it was stock. You can prolly align the door to minimize the gap.
Also there is no way you should have dents on the fender from the kit, the bolts are soooo far away from the outside of the fender it would never hit. Unless of course you didnt roll the inside of the fender when you put the kit on. Then the arm could come in contact with the fender pushing it out some
Old May 18, 2005 | 10:36 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
yeah i would have stayed oem...goodluck getting everything fixed though.
Old May 18, 2005 | 11:32 AM
Davey2Crazy
Ya ur prolly right i had sum1 else do the work so i dunt kno if the fender was rolled or not.. Dont worry ima keep to date and i'll upload sum pics so u cna guys see if i make out alrite lol
Old May 18, 2005 | 12:48 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
I figure out how rolling the fender could effect the body kit fitment?
Old May 18, 2005 | 08:11 PM
cobbcustomz
Body fittament is based on where the door is aligned at. It has multiple holes to bolt into and can be slid slightly in various directions causing the door to be out of alignment making it a poor fittament.
The dents in the fender could be caused by the fact that the fender isnt rolled and when the door is opened it pushes out on the fender causing dents or additional spacing between door and fender
Old May 19, 2005 | 04:00 AM
c_rogue69's Avatar
c_rogue69
wtf goes here?
I know all of that...the fender rolling I'm referring to is the kind if you're going to tuck your wheels. And if you align things properly (around the door area) you shouldn't have to roll your fenders in that way.
Old May 19, 2005 | 07:41 AM
cobbcustomz
You roll a different part of the fender. You roll the part closest to the door where it runs vertical I'll take pics later
Old May 19, 2005 | 06:20 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
^^I know what you're talking about though...I worked at a body shop for a year and a half and my dad has for 30 years.
