60k service 05 Si
I just got an 05 si today with 59k miles on it and im wondering what type of service needs to be done at 60k
Im guessing the usual 30k stuff: spark plugs, fuel filter, air filter, gear box oil but does this engine use a timing belt or chain and if its a belt is the service interval on it every 60k or 90k? Anyone with a service manual that could help me would be great thanks |
You could call the local Honda dealer and just ask. They are usually helpful and will tell you what is needed at 60k.
Yeah, it's a belt. You should get your timing belt, water pump & can't think of the other things.
I thought k-series had chains?
Not sure on that. I thought all the D,B,H & K motors had belts. I could be wrong..
i'm 100 percent sure that d, b, h are all belts.
i'm 99 percent sure that all K are chains |
It should all be listed in the owner's manual.
Pretty sure it has a chain (so doesn't have a scheduled replacement but should be inspected at 120k) but even the ones w/ belts don't require replacement until 90k. The MTF should be changed every 30k if not sooner so I'd do that. As for the spark plugs, I think the maintenance schedule for that year would be 90k replacement - factory plugs may be platinum - but wouldn't hurt to replace them early. edit: If it was my car I'd also change the P/S fluid at those miles, not a requirement but it's nice to know it's got fresh fluid. After having done it several times, I feel like it's better just to remove the fluid in the reservoir w/ a turkey-baster, etc. and refill with new fluid. Doing that at shorter intervals (or several times in a row after a short drive or just running the engine and turning the wheel lock-to-lock) seems just as effective and is less hassle than doing the procedure outlined in the owner's or service manual. Not that using the outlined method from the manual is hard, but newer models tend to foam up pretty bad unless you keep a constant flow of fluid into the feed line - if you don't do this you need to let the engine idle (or just drive it) for a good while before you can shut it off w/o it foaming out of the reservoir. On the older cars that wasn't really an issue. |
