tanabe lower underbraces installed
Old Sep 23, 2003 | 09:01 PM
boostlee's Avatar
boostlee
Default tanabe lower underbraces installed
hey all just got the front and rear tanabe lower underbraces installed. took about 2 months to get.
both fit very nice
the rear one you can see from the back and the front one is about 2 1/2"- 3" from the ground literally.
i will measure the hieght and put pics soon
handling is very good, i am 100% done with suspension
just need tires, bridgestone potenza re750
Old Sep 26, 2003 | 01:32 PM
Lude4Show93's Avatar
Lude4Show93
All Show No Go
what kind of suspension parts do you have? im just gonna get shocks springs strut tower and 2 sway bars, is there more you can get.
Old Sep 28, 2003 | 10:53 AM
boostlee's Avatar
boostlee
I got my suspension 100% done.
Koni Yellow Sport Adjustable Shocks
Neuspeed Race Springs
Neuspeed Front 25mm Sway Bar
Neuspeed Rear 25mm Sway Bar
Neuspeed Front Upper Strut Bar
Cucso Rear Upper Strut Bar
Tanabe Sustec Front Under Brace
Tanabe Sustec Rear Under Brace
Energy Suspension Hyper-Flex System
Energy Suspension Rear Trailing Arm Set
H&R 15mm Front and Rear Wheel Spacers w/ extended studs
Ingalls Engineering Front and Rear +1.25 to +3 Degree Camber Kit
Getting Bridgestone Potenza RE750 205/50/15 Tires this week
Updated Turbo Prelude Pics
Old Sep 28, 2003 | 02:26 PM
Hashiriya's Avatar
Hashiriya
yeah, get coilovers. And I do NOT mean Ground control or something like that, I mean like Tein's, Apex'i, HKS, Progress, or something that's the real deal. The Tein Type HA Flex is about as much as most people will ever need, plus they work with the EDFC, which is just damned neat.
Old Oct 3, 2003 | 06:00 AM
TimeRacer's Avatar
TimeRacer
Anyone that tells you Ground Control isn't a good "coilover" system doesn't know what they're talking about. If you get a full GC system with Koni's or Advanced Design shocks you have the same, if not better shock/spring combo than if you bought the Tein's. PLUS you don't have to worry about rust as you do with the Tein's due to their crap surface coat.
Old Oct 3, 2003 | 09:01 AM
monkey's Avatar
monkey
#212
the bottom line is that GC's aren't mated to whatever shock you combine them with, so they might work well, but they'll never ride as well as a full coilover setup. the difference is subtle but real. it probably matters more when daily driving.
also tein's updated SS and Flex setups are teflon coated for rust resistance now.
btw there is no tein HA flex, there's the HA which is discontinued as of recently, and not compatible with the EDFC; and the flex which is supposed to replace it, which is compat with the edfc.
