overheating
Old Sep 4, 2003 | 05:32 PM
sick79's Avatar
sick79
Default overheating
i noticed that my car would overheat at idle about a month or two ago. it would cool down after a minute of driving though. now it seems to do it more, especially if i push the motor hard. i figured it was the thermostat, which i replaced today, but the car still overheats. the weird thing is that as soon as the temp. guage goes past the halfway point(usually) 3 or 4 bars, i will turn the car off and if i imediatly restart the car, the guage will stay at the halfway mark. i would think that if the car was overheating before i turned it off, it should still be hot when i restart it 5 or 10 seconds later. the only mods that i have are cai and exhaust which i know are not the cause of overheating. i am on a tight budget, i am thinking about getting my radiator cleaned out, maybe that might help. both of the fans work also and the coolant is full. i do not leak any coolant either, and the coolant isnt tainted with oil. sorry that this is so long. any help will be greatly appreciated!!!!
Old Sep 4, 2003 | 10:00 PM
boostlee's Avatar
boostlee
year model of car.
did you bleed the coolant system of air through the bleeder valve??
Old Sep 5, 2003 | 03:16 AM
sick79's Avatar
sick79
my bad!!! its a 96 prelude s. as far as bleeding the cooling system, i drained about 1/8 of a gallon out of the radiator draincock, but i read my repair manual right now and and it says there is a bleeder valve on therm. housing. i will try that today. do air pockets really make that much of a differance? i asked my dad and he said no?
Old Sep 5, 2003 | 10:22 PM
senseiturtle's Avatar
senseiturtle
euro trash
Try replacing the radiator cap.
Sounds trivial and stupid, i know... but I was having the exact same problem with my eclipse. At a stoplight, or just idle, the car would begin to overheat, but it would quickly subside as soon as I revved it or began to move.
Turns out... the radiator cap was leaky, and the cooling system was losing pressure and some fluid. Easy do-it-yourself'er, or 20 bucks at pepboys. Worst case scenario, it isn't it, and you have a pretty new cap.
yeah... air pockets will definitley make that difference... screws up the pressure gradient needed to keep the fluid moving..
Old Sep 6, 2003 | 10:55 AM
sick79's Avatar
sick79
ACTUALLY, I WAS THINKING ABOUT GETTING A NEW CAP. THE CAP LOOKS PRETTY OLD, PROBABLY FACTORY ORIGINAL.
I BLED THE COOLING SYSTEM YESTERDAY, RAN FINE FOR ABOUT 45 MIN. I WAS STUCK AT A LONG LIGHT AND THE GUAGE ROSE A NOTCH HIGHER THAN HALFWAY. BUT I RAN INTO A DIFFERANT PROBLEM LAST NIGHT, THE TEMP. SKYROCKETED AFTER ABOUT 5 MINUTES OF DRIVING. THERMOSTSAT PROBLEM I GUESS, THE RADIATOR HOSE THAT CONNECTS TO IT WAS LUKE WARM BUT THE UPPER RADIATOR HOSE WAS BOILING. I JUST REPLACED THE THERMOSTAT TOO. THANKS FOR THE ADVICE, I WILL BE SPENDING ALL DAY TODAY FIXING MY CAR!!!!!
Old Sep 6, 2003 | 02:33 PM
importsyn's Avatar
importsyn
Is the thermostat "aftermarket"?I put in an aftermarket one in my car when it was overheateing and it lasted for 3 days!!!!After that I put in a Honda one and haven't had a problem since and that was 2 years ago.Talk about frustrating though.:madfawk:
Old Sep 6, 2003 | 02:55 PM
sick79's Avatar
sick79
WOW, I BEAT YOU BY ABOUT 2 DAYS! I PUT IN A CHECKER AUTO PARTS POS, AND I HAD TO TAKE IT OUT BECAUSE MY CAR WAS BURNING UP LAST NIGHT.IT LASTED FOR ONE DAY. I WAS JUST GONNA RUN WITHOUT A THERMOSTAT UNTIL NEXT PAYDAY, I LIVE IN PHOENIX AND ITS HOT AS HELL SO I FIGURED IT WOULD B OKAY. I STILL HAVE TIME TO RUN TO HONDA TODAY AND PICK ONE UP, SHOULD I? THANKS FOR THE HELP.
Old Sep 7, 2003 | 06:26 PM
boostlee's Avatar
boostlee
i cut out the middle of my stock thermostat =)
Old Sep 8, 2003 | 08:15 AM
sick79's Avatar
sick79
im gonna just buy another thermostat next week, but if my car still overheats, i may have to try that. the wierd thing is, after i took the thermostat out, i drove the hell out of my car trying to get it to overheat, it was mid afternoon and boiling hot. i even drove around in third gear for 3 miles, and went to mcdonalds and waited in the drive thru. my guage didnt budge. i went out later that night, and my guage went up a notch, wtf! im gonna get a new rad. cap soon, thats probably part of the problem. anyways, thanks for all of the advice everbody!!!
Old Jul 14, 2006 | 03:42 PM
Greg1116's Avatar
Greg1116
Default My Car Does It Too
My car also overheats. Took it to a mechanic and he cleaned my radiator, replaced the thermostat (after-market) and topped off the coolant. Still overheats. Could my engine block be clogged with deposits/gunk? Any advice?
