91 lude ac problem!!
Old Aug 27, 2003 | 11:56 PM
stickyshifter's Avatar
stickyshifter
Default 91 lude ac problem!!
Hmm, first time here. Hey people.
So after searching I finally got myself a 3rd gen 2.0 si prelude. At first I wanted an integra but finally decided on a prelude. It's such an amazing car! Well, for 137 HP it really flies!
Anyway, so everything is fine but for some reason when I turn on the AC, sometimes this litle red light on the buttom would come on and the AC would be disabled (compression light?). Sometimes pushing it off and back on works, but recently that failed, too. Could someone please give me some possible explainations on the reason and how to fix it?
Thanks for your time!
Old Aug 29, 2003 | 03:34 PM
boostlee's Avatar
boostlee
welcome
you my be low on freon and the compressor is kicking off to protect it from burning up.
you might need to recharge to system
boostlee pics
Old Aug 29, 2003 | 07:18 PM
Alan SH/4WS's Avatar
Alan SH/4WS
The problem when the red compressor warning light trips is the A/C control unit is "seeing" a difference in A/C pulley speed vs. engine speed. So, it shuts the compressor down in the event of the compressor ceasing. That way, if your compressor ceases, you won't shred the accessory belts.
There are four possible problems.
1) The drive belt for the A/C compressor is slipping, which obviously would cause a difference in compressor speed versus engine speed. Does your belt screech right before the compressor turns off? If so, just replace the belt.
or
2) The A/C control unit is bad. The control unit is a tan box located on the right side of the passenger footwell area. The control unit is the brain to the entire A/C system. It reads engine speed, compressor speed, compressor temperature, A/C switch activation, etc. You need a multimeter and a wiring diagram to test it. I think this box costs over US$150 or so at Honda.
or
3) The pickup sensor on the A/C compressor is bad (speed sensor)
More than likely it is the pickup sensor. There are actually two sensors on the A/C compressor that have to be replaced simultaneously (pickup sensor and thermal protector). Honda had a recall on these two sensors. The new ones have a blue stripe on the connector. I believe they are only sold as a set anyway. If you have a multimeter you can check the resistance of the sensors. You must disconnect the sensors near the A/C compressor. The pickup sensor (green wire and white wire) should have 450-600 ohms. If there is no continuity, it's shot. The thermal protector (red wire and brown wire) should have continuity (no specified ohm). You do not need to remove the A/C compressor to change the sensors out.
or
4) Compressor has ceased (doubtful) in which case you would have to replace it ($$$$$$$$!)
I would check through the list in the order given since it makes the most sense and it is the most cost effective as well.
Good Luck.
Alan
Old Aug 30, 2003 | 09:41 PM
stickyshifter
Thanks a lot guys! I am going to bring it to the dealer to take a look. Hopefully it won't be too $$$!
Thanks again for the help! Really appreciate it!
Old Sep 1, 2003 | 02:35 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
bravo Alan SH/4WS, I couldn't have said it better than that. You a Honda technician? I'm impressed if your not.
