Knock sensor
Old Jul 1, 2003 | 07:34 PM
BoOsTzex's Avatar
BoOsTzex
Default Knock sensor
can anyone tell me where my knock sensor is? its a 92 prelude si H23 engine, non vtec. Or maybe somone knows the symtoms of a faulty knock sensor, and if so how to test it?
Thanks :naughty:
Old Jul 1, 2003 | 07:45 PM
ludeboom's Avatar
ludeboom
indications/symptoms= you get a MIL code for knock sensor failure
its located right above the oil filter on the back of the block right below the bottom of the intake manifold.
new knock sensor for an h series motor will run you about $120 ish.
~boom
Old Jul 1, 2003 | 09:04 PM
BoOsTzex's Avatar
BoOsTzex
ok cool, so if i remove the filter it is accesable to test/replace? or does the manifold have to be pulled out for removing it?
Old Jul 1, 2003 | 09:19 PM
4bidden's Avatar
4bidden
You can get it out if you remove the filter no problem.
Old Jul 2, 2003 | 08:02 AM
BoOsTzex's Avatar
BoOsTzex
ok thanks!
