Needs some Input ASAP
Old Jun 27, 2003 | 03:21 PM
5thgenLude101's Avatar
5thgenLude101
Default Needs some Input ASAP
I know this topic has probably been covered a few times before, but I just want to be sure. I have a 98 Auto trans with sport shift. My car usually switches gears around 3k if you aren't stepping on it hard. I was wondering, how much abuse can the Automatic transmission/engine take? I mean is it ok to switch gears around say 5k or 6k instead of 3k? I just dont want to overwork my engine. I know some people run their engines till almost maxrev before switching gears, but everyone i've talked to who does that has a 5 speed manual, not an automatic. Just wanna know if it'll have an effect on the transmission over time or what? Any replies would be helpful. Also, about VTEC. I've heard the engaugment of Vtec occurs around 5k rpms, but I was wondering. Is this when you work your way up to 5k in say fourth gear? when your going like 120? or does Vtec kick in in like 1st gear if you rev the hell out of your car? I dont know why i'm confused by this, but like, if it kicks in around 5k in second gear, will it remain active once the transmission switches into third and the rpm's drop? Prolly baby questions to you guys, but I'm still learning about my first car hehe. Thanks! - Matt
Old Jun 28, 2003 | 04:55 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
from what I know, VTEC can be understood as just another section of the RPM range.
When the rpm's go above 5k, VTEC is active. When it's below 5k, it's not. I don't think it matters at all what gear you happen to be in.
Old Jun 28, 2003 | 05:06 AM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
Automatics don't take as easily to high revs as a manual. If you are using the sportshift alot, or run it in high rpms, make sure to have a complete flush of your tranny fluid every 30k. Not the 50.00 drain and fill, but the 150.00 complete purge. If you haven't had the service yet, do it ASAP. As for VTEC engagement, VTEC only engages at 4800 when under hard acceleration. It will not engage when you are cruising or under light acceleration. It's a vaccum control, so the engement is pressure activated. If you are in 4th, you probably won't hit VTEC unless you put the hammer down and downshift to third or second, since 4th is a cruising only gear.
