89 Prelude Break problem
Old Nov 27, 2002 | 08:59 AM
parcero's Avatar
parcero
Default 89 Prelude Break problem
I have an 89 Prelude that, according to the shop, has the rear calipers stuck closed. Therefore, the break pads in the back have worn out. Can this happen? Also, they are telling me that the calipers in the back are different then most, so they can't rebuild them. They are asking for $260 a caliper for each rear disk. Can someone fill me on this? Is all of this true, or can I just try to fix it myself? Also, is there any online repair manual that I can access? Thanks in advance!:thumbup:
Old Nov 27, 2002 | 09:36 AM
Kaspin's Avatar
Kaspin
1991 Prelude Si 4WS
It's possible for calipers to freeze up. but $260 each? that's nuts... you can get rebuilt calipers at nopionline.com for about $70 each, new brembo blank rotors are about $17 each, and pads are $20 for both sides (less than $200 total for all parts). installing calipers is fairly easy, the problem would be getting the frozen caliper off.
You can also try the junkyard for parts, ALL 3rd gen (88-91) REAR brakes are the same (the front ones are different between the Carburated models and Fuel Injected models)
Old Nov 27, 2002 | 11:29 AM
parcero's Avatar
parcero
Thanks a lot!
Old Nov 29, 2002 | 12:48 PM
parcero's Avatar
parcero
One more question: If I take out the calipers, will I be able to open and close them fairly easy. Or, will they really be stuck in whatever position?
Old Dec 3, 2002 | 11:43 PM
offthahook's Avatar
offthahook
Reppin' the 317, SUCKA!!
Remember, you screw in/twist rear caliper pistons! Do not put the C clamp on them!
