h22a civic swap??
Old Nov 12, 2002 | 12:27 PM
TaylorC01's Avatar
TaylorC01
Default h22a civic swap??
some some q's for you guys on the know how!! i got a 97 civic ex and i'm thinkin' hard about gettin' an h22a and havin' this local shop install it for me! so here is the q's
1. I got OBD II is there an h22a w/ OBD II?
2. If so, what year?
3. If not, then how hard and what would i need to do to make this swap work?
4. Is the h22a type s worth the extra money??
from what i gather the h22a has 200hp and the h22a type s has 220hp.
much thanx
and if any body has any info on putin' the new RSX Type R K20a into my year model civic it would be much welcomed!!
Old Nov 12, 2002 | 01:30 PM
epoxy's Avatar
epoxy
Regulator
well.. you have to get an obd1 => obd2 conversion harness. just a seach for it online (i recommend the skunk2 one..my friend has it, and it works fine)
well.. it is better, but not for the price you'll pay for it
the compression ratio is a little higher (11:1 vs the stock 10:1)
different internal motor parts... but i'd just get a USDM engine, and spend the extra $$ on aftermarket internals.
hope that helps.. need more info, just post.
Old Nov 13, 2002 | 09:48 AM
v4lu3s's Avatar
v4lu3s
1. anything 96+ is obd2
2. see question 1
3. no matter what you do you will need lots of wirirng done...whether its obd1 or 2...converting to obd1 means an obd conversion harness and soldering new plugs to fit obd1 injectors and distributor....it will be eaiser to stick with obd2.
4. if you are goin all motor....might as well since it will cost quite a bit to put in 11:1 pistons and so on....basically if you can afford it without taking money away from other parts of the swap go for it.
