92 Prelude (2.2 Automatic JAP Import) wont start!! HELP!!
On my way home from work today the car cut out and a light came on (looks like a box with wiggly lines coming out of it) which is apparently an exhaust temperature warning light? Upon closer inspection of the car, I found the sump plug had fallen out and I had no oil. I have since sorted this and filled the engine up with oil again.
However, the car still won't start and this warning light is still on, any ideas?
I have attached a picture (very bad phone pic, you can just make it out though) of the light if its any use....
Hope you can help,
Kev.
Hope you can help,
Kev.
No oil+Moving parts = Engine Seized up
You basically figured the problem out your self, I believe that symbol means the car overheated and seized up since there was no oil to buffer the pistons and crank causing them to over heat/expand and seize up....jack the car up, take the drivers side front wheel off and grab and wrench and a socket, and manually move the crank pulley...if you can't then the engine seized up
Yeah, the car was only £700 off ebay though to start with, probably best to call it a write off!! I'm gonna get a mechanic to take a look at it, if the engine's seized i'll probably try to sell on ebay for spares and just start again! Only had the car 2 weeks!!!
I think so, all the belts go round on the right hand side of the engine when trying to start it (you might have guessed I don't know a lot about cars....)
I'm assuming this means its not seized?
Sometimes it sounds like it is trying to fire (you get a very brief exhaust noise) but it never starts.
Any ideas? Is it likely to be anything simple (changing a spark plug or something) or will it be a mechanic job?
