94lube f22
Old Jun 3, 2007 | 03:26 PM
satuday's Avatar
satuday
Default 94lube f22
i just got a 94 lube got f22 with about 130k on it....alot of ppl telling me to put a h22 on it..but i just wanna rebuild the f22 and put a turbo on it coz its gonna be cheaper....can any1 tell me where should i start off with and which turbo should i put in and what HP can i get it to?
Old Jun 3, 2007 | 08:07 PM
ryan.warner's Avatar
ryan.warner
Got the same car bro. ecxept it has 175k on it and runs good with act acing clutch and koyo radiator, im looking to do the same. i want that same botom end cuz its really strong but i want a new head, maybe h23 or h22 i want to make the most power and than use a turbo....
Old Jun 3, 2007 | 09:05 PM
Fuse's Avatar
Fuse
http://www.honda-tech.com/zerothread?id=1046336 you both should try this.
Or get one of the f22b dohc engines(buy the way people reading this I have never seen one please post me a pick+where do thy come from? just wondering)
Old Jun 4, 2007 | 10:49 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
The F22B DOHC was the base model prelude in Japan....
Old Jun 4, 2007 | 01:41 PM
ryan.warner
Will that work with the f22 block?? with all those miles on it what should i do to the block beofer putting a new head on it?
Old Jun 4, 2007 | 01:43 PM
F22B Prelude
Rachel Bilson
Which head if you put the F22B head on it, its the same as an H23...I would do the complete swap if you had to do anything
Old Jun 4, 2007 | 06:01 PM
ryan.warner
a complete swap? what would you do? I want to make some good numbers without boost and than run a turbo after that..what motor would be a easy swap from the f22 sohc which i have now and i can use the act clutch with?
