no heat
Old Feb 7, 2007 | 11:10 AM
Niceprelude's Avatar
Niceprelude
Default no heat
[I ][/I] why suddenly no heat in my car with this cold weather
Old Feb 7, 2007 | 11:16 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Frozen
Heater Core
Thermostat
Old Feb 7, 2007 | 05:52 PM
Niceprelude
Frozen
Heater Core
Thermostat
do you mean it is too cold its frozen is it expensive to fix
Old Feb 8, 2007 | 06:49 AM
Bob Brock's Avatar
Bob Brock
Prelude 1992 Type S F22A
try also the flew cord its a small cord behind the the climate control panel that operates a flew that opens a flew for cold air to come in and closes it (for engine heat ) to come in. Its about and 35 dollar part from honda. But you'll have to switch it the other way in the summer. To do it right they told me it would be 175 dollars. ---> F22A prelude
Old Feb 8, 2007 | 08:26 AM
F22B Prelude
Rachel Bilson
Is your car overheating?
....after it gets warmed up pop the hood and feel the upper radiator hose, if thats warm then its not the thermostat
Old Feb 8, 2007 | 08:38 PM
Niceprelude
it is warm what next then
Old Feb 9, 2007 | 06:17 AM
Bob Brock's Avatar
Bob Brock
Like I said in my earlier post I had the same exact problem just go to honda they will charge you 75 bucks and fix it for you. Or you can take off the climate control and fix the flew wire yourself turn it to the closed setting and you will have heat.
Old Feb 9, 2007 | 08:49 PM
Niceprelude
what the hell today the weather is not so freezing it got heat.
Old Feb 12, 2007 | 08:40 PM
stereo's Avatar
stereo
the coolant might not have enough antifreeze thus freezing or the cable to the heaters water valve is bad.
Old Feb 12, 2007 | 10:12 PM
Niceprelude
true not enough coolant
