Sunroof Stuck
Old Jan 10, 2007 | 12:16 PM
ladybug_504's Avatar
ladybug_504
Default Sunroof Stuck
I have a 92 prelude si and the sunroof will not open. For a while I would have to give it a little push to get it open, but know it will not budge. I checked the fuse and that is fine. Help anyone??? I can't get it to open even a quater of an inch,,,so how do I lube it???
Old Jan 10, 2007 | 12:23 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Prolly just needs to be lubed up....My 92's roof is starting to stick as well
Old Jan 10, 2007 | 01:14 PM
TSG59_Steve's Avatar
TSG59_Steve
Um... where do you lube it if it can't open? I'm having the same problem in my 95 Ex.
Old Jan 10, 2007 | 01:20 PM
F22B Prelude
Rachel Bilson
YOu gotta get it open...I'm sure you can pry at it...But if the motor is burnt up thats another story
Old Jan 10, 2007 | 07:26 PM
stereo's Avatar
stereo
use the sunroof wrench thats with your lug wrench/jack stuff you remove the round plastic cover insert the wrench and open or close the roof.
Old Jan 17, 2007 | 08:05 AM
samsuwat's Avatar
samsuwat
mayb sunroof motor problems..
Old Jan 19, 2007 | 07:29 PM
gaborn73's Avatar
gaborn73
i bought some white lithium grease in an aerosol can (auto parts store)
and liberally sprayed the rails and it closes smooth like butter.
