RHD prelude harness problems
Old Dec 2, 2006 | 02:18 PM
imperialcustoms's Avatar
imperialcustoms
Default RHD prelude harness problems
i just did an RHD conversion to my bb4 and im using the rhd harness my motor ran fine before i took it all apart. i put it all back together now wen i start the car it will run at idle but the second u hit the throtle it stalls out not sure y maby vacume ran wrong or something not hooked up and ideas?
Old Dec 2, 2006 | 06:12 PM
Lynxx's Avatar
Lynxx
Methanol Drinker
The only suggestion I have is to look at all your wiring connections and make sure they're sound. Check grounds as well. It has to be something that you messed with...
Old Dec 2, 2006 | 07:06 PM
prelude1897's Avatar
prelude1897
Sorry this is off topic, but do you happen to have pics of the whole RHD conversion process? I'm going to be doing this as well to my 99 Prelude that I have chillin and waiting to be cut up
Old Dec 4, 2006 | 09:57 PM
stereo's Avatar
stereo
check that you don't have the TPS and map sensor plugs switched as it will start and idle but will fall flat on it's face if you hit the throttle.
Old Dec 9, 2006 | 07:17 AM
imperialcustoms
thanks for the help im checking all my wiring and grounds and will chech the tps and map if anyone wants pics email me at imperial85@aol.com but ill post some of the final product wen i finish up some body work
Old Dec 9, 2006 | 09:59 AM
imperialcustoms
switched the tps and map its running now thanks. but is showing code 43-fuel supply system it may be because i switched the inlet and plug side of my stock fuel rail. i was told i could do that but maby not like i said it ran fine befor, so its sumthing i messed up
Old Dec 10, 2006 | 08:02 PM
SirHybrid's Avatar
SirHybrid
Just extend your fuel line and re-route it to it's original location.
Old Dec 11, 2006 | 06:30 PM
imperialcustoms
i ran the fuel back to the stock side and its still showing the same code im drawing a blank with this one
