Lude Engine Changing
Old Oct 4, 2006 | 07:21 AM
Bob Brock's Avatar
Bob Brock
Prelude 1992 Type S F22A
Default Lude Engine Changing
I have a 92 honda prelude type S without the v-tec engine, and I have come to find out. It has a blow head gasket and the valves are scored. It will probbaly 2500 to fix NOOO!! But I had an Idea if I buy a good engin slightly used thats a v-tec it might be cheaper to just change out the engins. So what do you guys think would it be cheaper our should I just get orginal engin fixed or get it changed out. And would would changing out the engin to a v-tec have in it. My prelude is a type s with standart 2.2 liter 4 c engin with a automatic transmission.
Old Oct 4, 2006 | 08:12 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
H22 with your Auto transmission is pointless.....I would suggest looking into an F22B DOHC Engine.....Cheap and Reliable, and its a step-up from your F22A
Old Oct 5, 2006 | 07:44 AM
oscarhmoyano's Avatar
oscarhmoyano
If you need a new engine you can spend 3K and Vtec it ... 3K i think is reasonable with engine/labor/tranny/axles etc etc .... or fix your F22 (s) but F22's .. well you know aren't that great.
Oscar
Old Oct 11, 2006 | 09:30 PM
h22accord's Avatar
h22accord
155mph and still climbing
You can make an f22b or an h22a work with your automatic(I don’t recommend it with you stock trans but it can non the less be done). Some people on here don’t want to believe that but I have done it myself and its not what people on here make it out to be. But if you want to go the manual route its pretty easy to convert it, if you can find one in the junk yard. All you need is linkage, clutch/brake pedal assembly (including clutch master cyl) ecu and wire harness.
The absolute cheapest way will be buy an f22a from a 90-93 accord or another 92-96 prelude for like 200 bucks out of a junk yard, just put it in and call it a day.
Then your next cheapest choice is you could upgrade a little to the H23A/F22B. I don’t know anyone other than f22b prelude that has had much luck with the f22b swap, most everyone gets a knock sensor cel. But if you had the jdm f22b ecu I don’t think that would be a problem. Plus the f22b is pretty cheap and it has a reasonable amount of power. They still get beat by most b16 civics.
Next you could go H22A. You can get the JDM h22a with LSD trans (M2B4) for 2 grand and stomp the ish out of pretty much every other non-fi prelude. Its 200hp and if its not enough for you, then you can always add FI later. This is when you pretty much stop messin around with most na civics and step up to lightly moded mustangs.
Just my .02
