Not gaining speed
Old Jan 4, 2006 | 10:47 PM
hidewai's Avatar
hidewai
Default Not gaining speed
Is my fuel system clogged,is not gaining speed after about 35 miles. The rpm only go up to between 3k to 4k rpm need help guys..and anyone know how to get to the nissan site.
Old Jan 5, 2006 | 07:54 AM
mwprs37's Avatar
mwprs37
is it sputtering? how is it under 4K? hows the idle?
It really wouldn't hurt to change the fuel filter, maybe add some injector cleaner, try cleaning your TB as well....
Old Jan 12, 2006 | 10:40 PM
hidewai's Avatar
hidewai
when push the gas all the way to the floor,the RPM only goes to 4rpm to 5rpm and it get stuck between there, does not gain more speed. usually it pass the redline.need help.
Old Jan 13, 2006 | 03:25 AM
Sleeper Honda's Avatar
Sleeper Honda
check fuel pump, drain tank, clean and refill. this worked for my sentra.
Old Jan 13, 2006 | 12:02 PM
hidewai's Avatar
hidewai
fuel pump changed,tank is drain,how do you clean the tank.
Old Jan 13, 2006 | 01:43 PM
thecmfactor's Avatar
thecmfactor
is it an auto or manual? could be something with your tranny...
Old Jan 13, 2006 | 05:34 PM
Sleeper Honda
remove tank, wash it out with gasoline... clean and simple
Old Jan 13, 2006 | 07:32 PM
hidewai's Avatar
hidewai
auto the car still drive smooth,but only speed to 40mile to 45mile,i dont think the trans has problem
