exhaust problems
Old Sep 14, 2005 | 07:56 PM
jesseunvoas's Avatar
jesseunvoas
Default exhaust problems
i had the cat romoved and had a gutted cat put on now the mecanic said i will need to put on a resistor into the post cat oxy sensor now i was wondering if any one herd of this or knows what resistor to put in to slow the sensor down??
Old Sep 16, 2005 | 02:45 PM
jesseunvoas
no one??
Old Sep 16, 2005 | 06:02 PM
shivers's Avatar
shivers
Moderator Alumni
With a gutted cat or test pipe, the secondary o2 sensor with throw a CEL because it thinks your cat is not working. You have 3 options - live with the orange light staring back at you, make a mechanical o2 fix out of two spark plug foulers, or you can get an electronic o2 simulator and wire it in so it tricks the o2 sensor into thinking the cat is working properly.
2005 s2000
Old Sep 16, 2005 | 07:14 PM
jesseunvoas
this o2 fix out of two spark plug foulers speak more of this fix how easy is it or would it be more wise to get the simulator.
Old Sep 17, 2005 | 09:33 PM
shivers's Avatar
shivers
Moderator Alumni
Personally, I think the mechanical fix is the easiest option. The basic gist of it is, you pick up two spark plug anti-foulers from you local auto parts store. Then, drill out the hole in one of them with a 1/2" drill bit. This will widen the hole enough for the tip of the o2 sensor to pass through. You screw the o2 sensor into one of the foulers and then screw both foulers into the cat/test pipe/etc. Since the o2 sensor is moved back from the direct exhaust flow, it "thinks" the readings it's getting are correct and the CEL is eliminated.
Since you're using a gutted stock cat, you may only need one fouler for this to work. There's a lot of information available online on building this system. Search around. Good luck.
2005 s2000
Old Sep 19, 2005 | 08:12 AM
jesseunvoas
thanks that helps alot i will have to try it this weekend
Old Sep 20, 2005 | 12:49 PM
jesseunvoas
i found this http://forums.evolutionm.net/showthread.php?t=114931 i'm guessing it does the same so i'm gonna try it later this week
Old Sep 20, 2005 | 12:59 PM
DUNK_Performanc's Avatar
DUNK_Performanc
ThAiLaNd-Land of Smiles
Default have to give it to SHIVERS
I could not have said it any better myself, i tried telling friends about the same thing in teh past most have relocated it. but great 2 go
Old Sep 22, 2005 | 05:43 PM
jesseunvoas
wow i installed the fouler wednesday and my check engine lights been off for a whole day of driving i am amazed. thanks for the ideas
Old Sep 22, 2005 | 10:10 PM
DUNK_Performanc
we are so happy for yu, great. yu see as told since with a freer flowing cat, the O2 seinsor is in a direct flow of exhaust air, by adding the foulers it takes the sensore out of the direct low of exhaust air and minimizes it into something it normally is in. LOL This just lets yu kno HOW much yur catalytic converter restricts lol.
