Engine Problems
Old Jul 31, 2005 | 09:40 PM
GpoppLude's Avatar
GpoppLude
Default Engine Problems
Ok, the other day i was driving to work and noticed that i was running low on gas, so i filled it up. Not 2 miles down the road the car just dies everything gauges too. I dont think it is bad gas because i put in some water remover in the tank. The problem is still continuing all i have to do is put it in neutral and turn it back on, but its becoming an inconvenience. Any help is appreciated.
Old Aug 1, 2005 | 11:06 AM
RPV173's Avatar
RPV173
Wish i could help you, but i can't even get my car to start. Does your check engine light come on at all?
Old Aug 1, 2005 | 04:25 PM
brettybaby's Avatar
brettybaby
check your battery and see if it has any juice in it
and your alternator is probably bad
if you can charge your battery back up and grab a new alternator
that may be the problem. i know that happened to me a couple times and thats what i did
it could be something else
Old Aug 1, 2005 | 05:07 PM
squee's Avatar
squee
Check your coil. May also be your fuel pump, but the coil is more likely.
Old Aug 1, 2005 | 05:24 PM
VTEC-Power's Avatar
VTEC-Power
alternator is dead, it is not charging correctly
Old Aug 1, 2005 | 09:02 PM
GpoppLude's Avatar
GpoppLude
I did have a high amperage amp in there prolly put a big strain on it. but the car starts fine its just when im going down the road itll just shut off for now reason...
Old Aug 1, 2005 | 09:03 PM
brettybaby's Avatar
brettybaby
yeah maybe you have a wire that is grounding out that got cut or burned
one time my spark plugs got melted and the car would shutoff when the bare wires touched something
