help with changing fuel filter please
Old Jul 16, 2005 | 02:03 PM
ludin101's Avatar
ludin101
Default help with changing fuel filter please
all i need are some step by step directions on how to change that fuel filter. i have a 93 prelude si and need to know what i need to turn or close off. i know you disconnect the negative battery terminal and uncap the fuel take. what else do i need to do? where do i close off the high pressure lie?? and another dumb question. which way do i turn? righty tighty, lefty loosey?? help me
ludin
Old Jul 16, 2005 | 08:18 PM
ludeboom's Avatar
ludeboom
lefty loosy... righty tighty... for starters
its a 17mm if that helps
and it is TQ to about 30-40 ft lbs so dont fear gettin on it
there are two 12mm bolts holding the filter+bracket to the firewall, right near the ABS unit and the intake pipe and TB, remove the 12mm AFTER loosening the banjo (17mm) fuel bolt and the 14mm (i think) feed from the tank.
as far as pressure if ur not a total bitch then u can deal with a little fuel spraying when u loosen the banjo bolt. Just let the engine cool a bit thats all, dont do this right after getting off the highway.
any more Q's PM me....
kris
Old Jul 17, 2005 | 06:40 AM
foot's Avatar
foot
open the fuel cap. That'll keep all that fuel from turning you into a 911 call.
Old Jul 18, 2005 | 08:27 PM
ludin101's Avatar
ludin101
Thanks everyone for your help. the car runs better now. and they live happily ever after.
To Be Continued....
