rpm problems
Old Jun 25, 2005 | 10:48 PM
teamitr's Avatar
teamitr
H20LUDE
Default rpm problems
when I start up my car it idles at 3000rpm and when it warms up it idles at 1400-1500rpm what do you guys thing migth be wrong
Old Jun 25, 2005 | 11:21 PM
posite's Avatar
posite
My suggestions are to do the fast idle fix in which there are several good write ups you can find for it. Another idea you might want to look into is to check all your vacuum lines because a vacuum leak can cause it to idle high as well.
Old Jun 26, 2005 | 12:24 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
thast a little high for idle
it should be around 800 rpms when warmed up
check you idle control switch
Old Jun 26, 2005 | 06:44 PM
teamitr's Avatar
teamitr
H20LUDE
where is the idle control switch at? and I did check all vaccums
