Compression
Old Feb 22, 2005 | 12:47 PM
Unlimitation's Avatar
Unlimitation
Destiny SeekerZ
Default Compression
Hey guys I just bought a 98 Prelude. But now it won't run. :cbaby:
The mechanic said that it had something to do with the compression.
Is this something I should be worrying about?
Is this fixable?
Help please. Thank.
Old Feb 22, 2005 | 05:41 PM
sherwood's Avatar
sherwood
I missed Sean
ask in the engine tech forums, they'll tell you all about it
Old Feb 23, 2005 | 05:18 AM
shivers's Avatar
shivers
Moderator Alumni
What were the compression test results? Most likely your pistons rings are shot. They'll need to be replaced and the cylinder walls will need to be honed. Since the bottom end will be cracked open, you might as well consider replacing the main and rod bearings.
2005 s2000
Old Feb 24, 2005 | 06:11 PM
prelude97's Avatar
prelude97
Bad compression is BAD NEWS!!!! $$$ If your *lucky* the timing belt jumped a tooth causing poor compression and a no start condition, aside from that your SOL
