fukin weird...?
Old Sep 3, 2004 | 10:22 AM
biggjimmy7's Avatar
biggjimmy7
Holler
Default fukin weird...?
sup yall well i decided last night i was gonna get started on installing my amp/sub/compacitor. I went to the local store and coped a "LOC" Line Out Converter so i can run ac's from my headunit to my amp. well i installed everything but havnt actually hooked in the power because today when i wake up and go out to my car and turned it on it was idleing funny. the car only has 30k miles on it and i just put more oil in the car just in case but its still acting up.....it will sit there and bounce revs from 1k rmp to 1.5k rmp. also i went and drove it around the street and when you switch outta gears and put it in neutral at a stop sign it will rev at about 2k rpm for a second then go back to the bouncy rev's....any one else have this problem???
Old Sep 3, 2004 | 11:58 AM
GpoppLude's Avatar
GpoppLude
No never had a promblem with my idle after I installed my system, just needed a high output alt cause all the wattage I was running. Thats kinda wierd.
Old Sep 3, 2004 | 01:21 PM
98preludeSH's Avatar
98preludeSH
Dont know the fix, but you should just lose the system cause Ludes are heavy enough the way it is.
Old Sep 4, 2004 | 03:26 PM
biggjimmy7's Avatar
biggjimmy7
Holler
well i found out from honda today that my idle control unit has gone out so now i gotta spend $500 supposiblly for the new unit....wackness but atleast it wasnt my fault o well for that but thanks for info ne ways B_Ez
