Roar from rear
Old Aug 27, 2004 | 01:12 PM
tabasco's Avatar
tabasco
Default Roar from rear
We were test driving a '95 Prelude SE and noticed a roaring kind of sound coming from the rear axles or wheels. It only does it when the car is moving and increases in volume as the speed increases. Is this normal? What could be causing it? I'd like to know because apart from this, the car is in great condition.
Tabasco
Old Aug 27, 2004 | 04:22 PM
ludeboom's Avatar
ludeboom
wheel bearing
excessively low tread on tires
sticking rear caliper(s) or pads
warped rear rotors
~kris
Old Aug 27, 2004 | 08:20 PM
k.a.y's Avatar
k.a.y
tires mounted backward/diffrent tread patterns between left/right tires.
Old Aug 27, 2004 | 11:40 PM
monkey's Avatar
monkey
#212
i'd say wheel bearings.
Old Aug 28, 2004 | 07:33 AM
MINI NSX's Avatar
MINI NSX
Also tires that have been out of balance and are cupped will roar.
Old Aug 28, 2004 | 01:14 PM
tabasco's Avatar
tabasco
Can anyone place a general price on:
Two rear wheel bearings
Two rear rotors
Two rear calipers
Also, what kind of tires (15" rims) would you recommend for a smooth ride that corners nicely.
Ed
Old Aug 28, 2004 | 01:23 PM
ludeboom's Avatar
ludeboom
www.rockauto.com
thats where i get most of my reman stuff, like calipers/rotors there prices are superb in that category.
the wheel bearings u will want www.hondaautomotiveparts.com, they will be listed under (rear brake?)
if i were you i would try to determine which side is making the noise...also dont forget that caliper failure/sluggishness is very common if the car has been sitting for several months, along with the rotors getting rotted or warped.
~kris
Old Aug 28, 2004 | 02:09 PM
tabasco's Avatar
tabasco
The car has been sitting in a garage since April. Also, the rear tires are in need of replacement. If I put a penny in the tread, it falls between the edge and the top of Lincoln's head.
Ed
Old Aug 28, 2004 | 04:59 PM
Samson's Avatar
Samson
chris is the devil
low tread... many tires will howl.
