Camber Kit
Old Aug 4, 2004 | 11:56 AM
chizzums's Avatar
chizzums
92 Prelude Si
Default Camber Kit
92 Prelude - If you have lowered your prelude what kind of camber kit did you buy. I am needing a front and rear cause my tires are wearing a little faster than i thought. Also, tell me how much you paid for the set.
Old Aug 5, 2004 | 01:16 AM
monkey's Avatar
monkey
#212
all prelude camber kits suck. the best of the crappy bunch is the SPC ball jt kit.
i'm running no name Front ball joints, rear anchor bolts.
they will cause your control arm/upper ball jt to hit the top of the wheel well when your suspension compresses alot. it will sound like hell.
tire wear is kind of affected by camber, but not nearly as much as it is affected by toe.
Old Aug 5, 2004 | 10:35 AM
5hift's Avatar
5hift
Hades: 2.2L DOHC VTEC
Yah, but even if you get ur car aligned and the toe is set to 0, you can still have camber. Look for an Ingall's camber kit. I've heard a lot of good things about em and I'm getting mine out on my car as I type this.
Old Aug 6, 2004 | 01:26 AM
monkey's Avatar
monkey
#212
well, the point is, is that camber won't really mess up your tires as much as people says it does. sure it helps wear down the tread, but with proper rotation and reasonable camber rates it won't be that bad.
Old Aug 6, 2004 | 08:42 AM
5hift's Avatar
5hift
true, but this is only if you're lowering your car about 1.5" . From 2" on down, you're looking at some serious camber which will definitely takes its toll on your tires.
