cooling fan problem
Old Apr 11, 2004 | 05:16 PM
joostdyk's Avatar
joostdyk
eluded si
Default cooling fan problem
okay here's the problem...
i just put a h22a into my 94 prelude si this weekend. it started up great and everything works except when the car is running, the cooling fan doesn't run even with the heat on high. when i shut the car off, the fan kicks in and won't stop until i pull the relay. i don't know what's causing this. would anyone have any suggestions about it?
Old Apr 12, 2004 | 07:36 PM
joostdyk's Avatar
joostdyk
eluded si
*bump* anybody...
Old Apr 14, 2004 | 08:53 PM
BluLude's Avatar
BluLude
the fan wouldnt come on if you turn the heat to high...unless you turn your A/C on...turning the heat to high helps cool the motor down so the fan doesnt need to come on...
Old Apr 25, 2004 | 06:26 PM
drift's Avatar
drift
Flaccid Member
since the car senses the motor temp after shutdown, it's likely your fan temp switch is bad. the temp switch is located at the head, under the dizzy if i remember correctly. this is what monitors coolant temp and signals to the fan relay.
Old Apr 26, 2004 | 05:45 AM
ludeboom's Avatar
ludeboom
i thought the fan switch was located on the radiator? either way, its definitely the fan/thermo switch
~boom
Old Apr 26, 2004 | 03:24 PM
drift's Avatar
drift
Flaccid Member
~boom
that's the radiator and condensor fan relays.
Geckoboy
Engine Swaps, Tech & Tuning
7
Feb 12, 2004 12:19 PM
s1ngle
92+ Civic/EL & Del Sol
38
Dec 30, 2003 12:09 PM
reddemon009
Nov 4, 2003 06:59 AM
Meguel24
Oct 23, 2003 01:49 PM
drmeatrx
4
Feb 9, 2003 06:56 PM
