h-22 knock sensor
Old Nov 9, 2003 | 06:48 PM
dcbreed's Avatar
dcbreed
Default h-22 knock sensor
i am having problems with a knock sensor i replaced it twice and checked the wires and wires are good and when i drive the car and get above 5000 rpm the check engine light comes on and i get a code 23 which is the knock sensor is there anyone who can help me to understand what is going on. i also want to know if the knock has something to do with the vtec.
Old Nov 9, 2003 | 11:01 PM
squee's Avatar
squee
Well, knock sensors dont really go bad, as long as you have reset your ecu its either the wiring/ecu, or knock. when did this start happening? What did you do to your car before this started? anything? are you using 93octane?
Old Nov 10, 2003 | 05:36 AM
dcbreed's Avatar
dcbreed
yes i am using 93 octane and when it does it am putting a load on the motor and acclerating over 5000 rpm.
