F/S Alpine CDA-7995--brand new--$300 plus S&H
A brand new Alpine CDA-7995 in box for sale. It was never installed and if you are interested I am selling it for $300 plus S&H brand new(will provide pics upon request to prove that unit is brand new) Only reason box was opened was to admire the unit. Cheapest I have ever seen this is at www.autotoys.com for $389.95. Retail this unit will sell for close to $450 or $500.
You can email me at 98ex@nextgenads.com IM me at B18C1Sleeper on Aim or Yahoo or PM me here. |
Ok went to alpines site and pulled this
http://ecominet2.alpine-usa.com/img/asb/cda-7995.gif and here are the specs for the unit Bass Engine® Plus - Media Xpander™ - 4-Channel Digital Time Correction - 3-Position 12dB/Octave Crossover - Subwoofer Level Control with Phase Selector - Bass Center Frequency and Width Control - Treble Center Frequency Control • XM Satellite Radio Ready • MP3, CD-R/RW Playback • CD Text and MP3 ID3 Tag Information Display • Versatile-Link™ Ready • KCA-410C Multi-Versatile Link Terminal Compatible • MaxTune SQ Tuner • Blackout Display • Regulated 1Bit DAC • 4 Volt PreOut with DC-DC Converter • 3 PreOuts • Swing Mechanism with Detachable Face • RUE-4187 Wireless Remote Control Included ----------------------------------------------------------- CD Player CD Text, CD Text Display, CD Text Scroll CD-R/CD-RW Compatibility Digital Servo Disc Play/Pause Disc Title Memory Forward/Backward M.I.X. (Random Play) MP3 Decoder/Playback Music Scan/Repeat Music Sensor (Up/Dn) Regulated 1-Bit DAC CD Shuttle Control CD Text Display/Scroll Disc Play/Pause Disc Title Memory Forward/Backward M.I.X. One/All (Random Play One or All) Multi-CD Changer Control (with KCA-410C) Music Sensor Up/Down Repeat General-Head Units 3-Position HP/LP Crossover (12dB/Oct.) 4-Channel Digital Time Correction Bass Center Frequency Control Bass Width Adjustment Media Xpander™ (MX) Subwoofer Level Control Subwoofer Phase Control Treble Center Frequency Control 3 PreOuts 3-Color Display with Spectrum Analyzer 4 V PreOut with DC-DC Converter Anti-Theft Detachable Front Panel Bass Engine Plus® Black Out Display Detachable Trim Plate Dimmer-on Input Fader & Balance Controls ISO Mount Capability Power Antenna Lead Remote-on Lead Rotary Encoder Volume Control S.T.M.(Source Tone Memory) Separate Bass & Treble Control Silver Swing Face Mechanism Versatile Link Ready Wireless Remote Control Included Tuner Auto Memory Local/DX Selection MaxTune SQ Tuner Preset Address Indicator Preset Stations (FM:12/AM:6) Station Title Memory Title Search Menu/Scroll Up/Down Seek XM Control Category Search Preset Memory (12 total) XM Ready XM Text Scroll AM Tuner Tuning Range : 530-1, 710kHz Usable Sensitivity (IEC Standard) : 22.5/27.0 (µV/dBf) Bass Engine® Bass Center Frequency (Selectable) : 60Hz, 70Hz, 80Hz, 90Hz, 100Hz, 130Hz, 150Hz, 180Hz Bass Level Control Range : ±14dB at 60Hz (2dB steps) Bass Width Adjustment (Q) : 4 Choices (1= Wide, 4=Narrow) Crossover Type : Independent HP/LP (2-Way) Analog High Pass Crossover Frequency (Selectable) : Off, 80Hz, 120Hz, 160Hz Low Pass Crossover Frequency (Selectable) : Off, 80Hz, 120Hz, 160Hz Media Xpander™ AUX Settings : MP3 , Music, Movie (Level 1, Off) Media Xpander™ Modes/Level : FM, CD, XM, MP3 (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off) Number of Time Correction Channels : 4 Independent (FL, FR, RR, RL) Subwoofer Level Adjustment Range : -15dB to 0dB (1dB steps) Subwoofer Phase Control : Normal (0°) or Reverse (180°) Time Correction Adjustment Range : 0.0ms to 9.9ms (99 Steps) Treble Center Frequency (Selectable) : 10.0kHz, 12.5kHz, 15.0kHz, 17.5kHz Treble Level Control Range : ±14dB at 10.0kHz (2dB Steps) CD Player Channel Separation (1kHz) : 85 dB DAC Type : Regulated 1-Bit Dynamic Range (1kHz) : 95 dB Frequency Response : 5-20k ±1 dB Number of DACs : 2 Oversampling : 8X/352.8kHz Sampling Rate : 44.1kHz Signal-to-Noise (S/N) : 105 dB Total Harmonic Distortion (THD) : 0.008% (at 1kHz) Wow & Flutter (%WRMS) : B.M.L FM Tuner 50dB Quieting Sensitivity : 13.5 dBf(1.3µV/75 ohms) Alternate Channel Selectivity : 80.0 dB Capture Ratio : 2.0 dB Mono Usable Sensitivity : 9.3dBf (0.8µV/75 ohms) Signal-to-Noise (S/N) : 80.0 dB Stereo Separation : 45.0 dB Tuning Range : 87.7-107.9MHz General-Head Units Chassis Size (W x H x D)in : 7"x2"x6-1/8" Chassis Size (W x H x D)mm : 178mm x 50mm x 155mm Maximum Mounting Angle : 30° from Horizontal Nose Piece Size (W x H x D)in : 6-3/4" x 1-13/16"x 11/16" Nose Piece Size (W x H x D)mm : 170mm x 46mm x 24mm Operating Temperature (°C/°F) : 60°C (140°F) to -10°C (14°F) Power Requirement : 14.4V DC (11 –16 V allowable) Pre Output Voltage (Before Clipping) : 4 Volts Weight : 1.5kg (3lbs. 5 oz) Remote Control Battery : 2 x "AAA" Dimensions (W x H x D)in : 1-21/32" x 4-25/32" x 29/32" Dimensions (W x H x D)mm : 42mm x 121mm x 23mm Model Number : RUE-4187 Weight : 50g (1.80z) |
