Big parts list.. EG,EF,EJ1 CRX LOOK
SO Im doing some spring cleaning and have so many parts... I will break it down with a list and what its for.. I am in process of taking pictures.. So here we go send me a text 24/7 at 262 744 0630::
88-91 DX hatch
Glovebox Blue
Windshield washer bottle
Gas fuel door primered
Outer door moldings/brackets
rear outer window molding brackets
windshield wiper motor and linkage
hood hinges
Full ignition and lock set all with one key.
interior door latches d/s and p/s
center console
gauge cluster surround console
interior door pouches d/s and p/s
d/s and p/s manual window regulators
rear seat latches
oem antenna
dash coin pouch
hazard button
windshield wiper arms
seat belt buckles
rear hatch molding
trunk/fuel door release
Rz-0063 main fuel relay
front knuckles with calipers
rear trailing arms
full oem suspension
88-91 civic steelies need tires
d/s and p/s window
d/s and p/s rear window
so much more pm me what your looking for.. more to come to every list as well
off a 88 CRX DX front brake calipers
93-97 Honda Del sol Parts
Del sol rear sails 3 pieces white
Black oem steering wheel
front brake hoses/lines oem
steering column with tilt
Ignition with key
full honda civic del sol ignition set and door handles complete
interior a/c harness
wiper/headlight combo stalks
roof warning relays
gauge cluster harness
gauge cluster harness SI
under dash fuse box and fuses
power window control relay
hood release
climate control harness
trunk side carpet light
srs unit
sun visors pair
passenger side window switch
(2) driver side window switches
p/s small window
p/s window molding
Driver side sunvisor
p/s inner door latch
p/s door harness
p/s door hinges
p/s window regulator
d/s window regulator
94 SI airbag harness
p/s door hinges
tarmac roof mechanisms
Driver side a pillar tapped for gauges
Black ebrake
lower steering column cover small crack but works perfect
upper third brake light long brake light
upper gauge cluster console trim
5 oem horns for civic/del sol etc
white fuel door
rear window molding
D series starter
cruise control motor and cable
black gas tank door
red gas tank door
VSS sensor
p/s seat belt
gas release cable
throttle cable
D/s headlight harness
interior evaporator/blower harness
5 speed pedal assembly SI
Brake master cylinder/booster combo
brake booster
D/s and p/s mini windows
heater box/blower
Si airbag harness
oem jack
white trunk hinges
black trunk hinges
D/s and p/s lower door weather moldings
clutch master cylinder and reservoir
trunk molding
rear window molding
tarmac roof headliner
tarmac roof trim plastic 3 pieces
tarmac roof White
oem carpet
trunk carpeting
oem altezza tailights
p/s fender white
white front bumper
rear bumper
crash beams
so much more again pm me what you need..
92-95 EG hatchback
Black Ebrake
D/s airbag Black
rear window outer moldings
small fender moldings
2 overflow coolant bottles
hood hinges
sunvisor clips
p/s inner taillight
p/s black seat belt buckle
grey interior door pouches
grey mini dash vents also have black ones
d/s interior mirror trim
Stinger battery cables
Black ebrake console
p/s black airbag tray
srs unit DX
d/s and p/s interior door latches
airbag harness
black front speaker covers
domelight
tailgate wiring harness
p/s door hinges
tailgate molding
under hood fuse box and fuses
so much parts for these so just pm me and see what we can do..
92-95 civic ex coupe
d16z6 ps pump
d16z6 ps pump bracket
rear trunk garnish Purple
purple trunk
white trunk with spoiler
grey power door panels bare
full weather moldings for driver side and passenger side NICE
d/s and p/s headlights
eg full hood latch assembly/cable/release
white fuel gas door
d/s and p/s grey seat belts
p/s headlight
EX srs unit
grey steering wheel
95 honda civic owners manuals
trunk molding
driver window
passenger window
green p/s outer door handle
oem battery tray
abs sensors front
automatic pedals
grey ebrake
black mini dash vents
hood hinges
airbag harness
a/c evaporator
d/s and p/s outer taillights
engine mounts
airbag harness
p/s door hinges
trunk molding
gas lid cable
hood washer hoses
full trunk/fuel release with cables and trunk latch
rear speaker panels
purple gas lid
windshield washer bottle
front speaker panels
grey 3rd brake light
(3) rz-0132 main fuel relays
tons and tons of stuff... pm me what your looking for... paypal accepted on everything or money order.. and can ship it all...
AND now just added a new teal green civic ex coupe full partout.. motor and tranny is sold already...
88-91 DX hatch
Glovebox Blue
hood hinges
center console
rear seat latches
oem antenna
dash coin pouch
hazard button
seat belt buckles
rear hatch molding
rear trailing arms
full oem suspension
d/s and p/s window
Ignition with key
roof warning relays
hood release
srs unit
sun visors pair
p/s small window
p/s window molding
p/s door harness
p/s door hinges
p/s door hinges
Black ebrake
white fuel door
rear window molding
D series starter
black gas tank door
red gas tank door
VSS sensor
p/s seat belt
gas release cable
throttle cable
brake booster
heater box/blower
Si airbag harness
oem jack
white trunk hinges
black trunk hinges
trunk molding
rear window molding
tarmac roof White
oem carpet
trunk carpeting
p/s fender white
white front bumper
rear bumper
crash beams
92-95 EG hatchback
Black Ebrake
D/s airbag Black
hood hinges
sunvisor clips
p/s inner taillight
srs unit DX
airbag harness
domelight
p/s door hinges
tailgate molding
d16z6 ps pump
purple trunk
white fuel gas door
p/s headlight
EX srs unit
grey steering wheel
trunk molding
driver window
passenger window
oem battery tray
abs sensors front
automatic pedals
grey ebrake
hood hinges
airbag harness
a/c evaporator
engine mounts
airbag harness
p/s door hinges
trunk molding
gas lid cable
hood washer hoses
rear speaker panels
purple gas lid
