JDM OBD1 b16a motor
Old Apr 8, 2007 | 03:52 PM
igot3240's Avatar
igot3240
Default JDM OBD1 b16a motor
I have a complete jdm obd-1 b16a motor for sale. It was pulled out of my brothers del sol to be replaced with a gsr motor. It runs very strong, and has no problems, , Mileage is approx...55,000 miles on it. When it was purchased it had about 47K on it and then approx 8K miles was put on it.....It includes pretty much everything. The only thing it needs is 2 flywheel bolts and Spark plug wires, the flywheel is included, and has been resurfaced about 8K miles ago. ..It does have all sensors, the vtec solenoid, intake and exhaust manifolds, and alternator. The distributor is included, but needs a coil or ignitor. the motor is very very clean...A JDM P30 will be included. All these parts were installed by a ASE master tech approx. 8K miles ago:
Spoon Headgasket, New Head Bolts were purchased and used.
NGK Iridium IX Spark Plugs
Rear Main Seal
Front Crank Seal
Timing Belt Tensioner & Timing Belt
Water Pump
Cam Seals
Cam Plug
Fuel Injector O-Rings
Valve Cover Gasket Set w/ Valve Cover Grommets
Valve Adjustment
All of these replacement parts was OEM Honda.
$750 shipped
or pick up!
email me at igot3240@yahoo.com
thanks
Attached Thumbnails JDM OBD1 b16a motor-b16.jpg   JDM OBD1 b16a motor-b162.jpg   JDM OBD1 b16a motor-b163.jpg   JDM OBD1 b16a motor-b164.jpg
Old Apr 8, 2007 | 04:34 PM
SpeeedFreak's Avatar
SpeeedFreak
where are you located?
Old Apr 8, 2007 | 04:36 PM
igot3240's Avatar
igot3240
georgia.
Old Apr 19, 2007 | 06:47 PM
stain031's Avatar
stain031
Default motor
can u ship to 12524
