Garage sale Milwaukee, WI All motor parts/ some turbo parts. Random stuff FS.
FS- UPDATED Today!
b-series vtec valve cover-$25
b-series vtec spark plug cover-$15
Or both for $35
4 wire o2 sensor-$20
'95 Gsr power steering pump with brackets-$40
99-00 B16 SI power steering pump with brackets-$40
Both in perfect working condition.
b-series hydro halfshaft-$30
b-series cable halfshaft-$30
b-series hydro drivers side axle-$25
2 b-series passengers side axles (need boots)-$10
b-series hydrolic shift linkage (comes with shifter-$40
Bosch 044 external pump. Comes with bracket and -6an fittings. Has less then 1500 miles on it. Mint cond. $175
RCI 5 gallon fuel cell. part # rci-2050D. You can use either the -8an lines or i'll include a set of -6an fittings. I also have about 20ft. of -6an russell's steel braided lines and an external fuel filter-offer
Mint tenzo bucket seat. No rips, tears, fading etc. If you need a bracket for it i have a few for 92-00 civic's.-$100
Selling MINT 15" rota Jmag's. Bought them about a month ago. You won't see 1 scratch on any of them! They are dirty in the picture, 100% polished. I have all original boxes and center caps for them. 2 of the tires are new g-force bfg's 205/55/15r. I will take off the other 2 tires which are bfg drag radials since i paid a lot for them. All you will need are 2 tires. Paid $550 for them. $499 picked up!
JDM ef8 crx front fog lights. 1 of them is still intact with just a hairline crack in it which you can't notice. Other one is cracked and worthless. Give me an offer on the 1 if you want it.
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it. Stock Type r LSD with 4.40 Final drive. -$1400 well worth it. Add up the synchros+other parts + labor and your basically getting the tranny for free.
I ALSO have a stock JDM type r tranny for $900 in mint condition.
CNC Reverse throw clutch pedal with master cylinder- For all you guys that want to convert your car to true hydrolic this is what you need. All you do is just run your -3an line straight to your clutch slave cylinder-$70
Schedule 40 stainless steel(glass beaded) butt-welded RAM style turbo manifold for b-series. Beautiful manifold, before pic of it glass beaded.. after pic looks nasty since it got all greased up with oil while removing it. Motor made 550whp with this manifold. Has 44mm Tial vband flange on it and it's turbine flange is a t3. It's not ac compatible but you can use power steering (just have to trim the top bracket a little bit) $450
Modified Avid racing traction bar for 88-91 Civic/Crx's. This is what all you turbo guys need if your 3" or even 4" downpipe hits the traction bar. Has mad clearance.$200 + your stock one.
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300
RARE '91 LSD Y1 cable JDM tranny. NO grinds. picture of tranny before i installed it on my ef8. '92 JDM b16a engine is also for sale. Bone stock has 65K on it!! Runs great, doesn't burn any oil etc. Come check it out before you buy! I'm looking to sell the complete swap OR i'm willing to part out and sell everything seperately such as the tranny, complete b16 head or block. Throw me some offers or pm me if interested. :thumbup:
TI-83plus graphing calcutor, perfect working condition-$25!
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something -$25
big yellow wastegate spring for tial 44mm wastegate (7 psi)-$15
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
P72 stock rods $10
ecu's-...
obd0 91 pm9-10
obd0 91 pm5-10
obd0 88 pm6-10
obd0 89 pm6-10
obd0 91 pm9-10
obd0 91 pr4-20
obd1 93 pr4-20
obd1 94 p06-20
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
88-91 Civic/Crx steering column with tilt-$20
b-series upper and lower alternator brackets-$20
7/8" civic/crx brake master cylinder-$10
b-series hydro slave cylinder-$10
1 wire o2 sensor-$5
(2) b-series rear T brackets from 99-00 si-$30 each
(2) resistor boxes-$10 each
b-series fuel rail-$10
b-series fuel regulator-$5
90-93 DA integra hubs-$15
92-95 Civic front shock forks-$15
(2) lower b-series power steering brackets-$5 each
88-91 Civic/Crx radiator fan-$10
94+ integra radiator fan-$10
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side- $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
Msd blaster 2 coil-$25
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
Anyone interested in any parts PM me
Or both for $35
P72 stock rods $10
ecu's-...
obd0 91 pm9-10
obd0 91 pm5-10
obd0 88 pm6-10
obd0 89 pm6-10
obd0 91 pm9-10
obd0 91 pr4-20
obd1 93 pr4-20
obd1 94 p06-20
1 wire o2 sensor-$5
Windows-
$35 each!
