A few B-Series parts all of them are new.
Old Dec 14, 2005 | 07:08 PM
SIR3099's Avatar
SIR3099
Default A few B-Series parts all of them are new.
Lightened Honda B-Series Flywheel
MSRP $349.00 USD
Asking: $230 shipped in North America.
This is a balanced flywheel made from hardened chrome-moly steel.
Performance: Dramatically improves throttle response and clutch feel.
Application:
- Acura Integra (all models) 1990-2001
- Honda Civic SI 1999-2000
- Any B-Series hybrid motor (LS/VTEC or CRVTEC)
- Any US or Japanese market B16A, B16B, B18A, B18B, B18C, or B20B
Headers - 4-1 ITR Header Stainless Steel
MSRP $499.00 USD
Asking: $319.95 shipped
Yonaka Motorsports headers for all B-Series motors featuring 1 5/8" pipes with 2.5" collector flange.
This is an aftermarket header, designed for the JDM 1998+ Integra Type R B18C engine.
It has all the fitments for the OEM upper and lower headshields. This header is identical to the JDM Honda Integra Type R except ours is fully polished (unlike the unpolished, rusty one from the factory piece).
This header is fully polished stainless steel.
B16 or B18 DOHC VTEC Engine Gasket Kit
MSRP $249.00 USD
Asking: $149.95 shipped.
This is a complete aftermarket engine gasket set for the Honda JDM B16A1 1.6L DOHC VTEC engine. Can also be used for the Acura Integra 1.8L GS-R B18C1 and Acura Integra 1.8L Type-R B18C5.
NOTE: The intake manifold gasket will not fit the GS-R motor.
Set includes: Cylinder head gasket, intake manifold gasket, exhaust manifold gasket, valve cover gasket, valve cover grommets/seals, cam seals, valve seals, injector O-rings, oil pan gasket, waterpump gasket, main crank seal.
Weight: 2 lbs.
Dimensions: Stock OEM size
Performance: Stock OEM performance
Application: Can be used for JDM or USDM models.
Warranty: One year warranty
Honda B16A (Left and Right)
MSRP $299.00 USD
Asking: $179.95 shipped
This is a pair of axles (left side and right) designed for 90-93 Acura Integra manual transmissions.
Application: Perfect for any B-Series engine swap into an 88-91 Civic or 90-93 Integra with cable transmission.
Note: These are for non-ABS vehicles.
Intercooler Type 9 18x6x2.5"
MSRP $399.00 USD
Asking: $199.00 Shipped
This is a full aluminum intercooler with polished cast end tanks.
Dimensions:
- Bar and plate design
- End to end length with endtanks: 26"
- Core Size: 18" long x 6" high x 2.5" thick
- Inlet/outlet diameters: 2.5"
Performance:
- Supports more than 275 hp
- Flows up to 350 cfm
- Leak tested at 30 psi
Application: Designed for use in any custom or upgraded stock turbo setup. It is perfect for any big-boost application for Honda.
I am Paypal Verified with a great rating. In addition to that, I have an ebay feedback of 91 all 100% positive. If you would like proof just e-mail me at sw_viper3099@hotmail.com
Thanks guys, I need these parts gone. I even made the post pretty lol.
Attached Thumbnails A few B-Series parts all of them are new.-b-series-flywheel-front-.jpg   A few B-Series parts all of them are new.-90-93-integra-axles.jpg   A few B-Series parts all of them are new.-d16y5.jpg   A few B-Series parts all of them are new.-jdm-header-steel.jpg   A few B-Series parts all of them are new.-extended-thin.jpg
Old Dec 14, 2005 | 08:06 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
your header seems a little overpriced, seeing you can get them on ebay for 150-200$...but bump for a well written post
Old Dec 16, 2005 | 05:30 AM
SIR3099's Avatar
SIR3099
I have a mild steel one for $200 USD shipped actually. The polished stainless steel ones are a little pricy. Ebay, god knows how they make their headers.
Old Dec 16, 2005 | 05:37 AM
SIR3099's Avatar
SIR3099
Shocks - Honda Civic Coilovers 92-95 EG
MSRP $899.00 USD
Asking: $525 shipped
Yonaka Motorsports street coilovers for all 1992-1995 Honda Civics. Ideal for street cars and weekend racers.
Featuring:
All Aluminum Upper Mounts
0-4" Height adjustment.
Fully Threaded Mono Tube Shock Absorber.
Inner bump stop to prevent damage cause by rapid compression impacts.
Wide range of height adjustment without changing the spring compression.
Bottom of the shock is threaded to allow height adjustments without having to shorten the suspension travel.
Rubber dust shield protecting piston for long life.
Adjustment tools included.
Spring rates are as follows:
Front springs: 12kg / 180mm
Rear springs: 6kg / 200mm
Remember, this isn't just coil-overs, its both shock and coil. These are not ebay coil-overs either that have a really crappy ride (Personal experience).
Honda Civic 92-00 Catback Exhaust
MSRP $379.00 USD
Asking: $299 shipped.
This complete catback exhaust will fit all Honda Civic 2dr coupes and 4dr models from 1992-2000. It will not fit hatchback 3dr models. This system consists of 2.25" diameter stainless steel piping with a 4.5" muffler tip. The silencer can easily be removed for maximum power, and replacing it can be done in under 1 minute.
Yonaka Exhausts are available for more popular applications and feature:
- Bolt in fit for popular applications
- Mandrel bend piping for smooth exhaust flow
- TIG welded
- Fully polished stainless steel
- Tunable Exhaust Tip
