D16Y8 Vtec Head, $50. Plus some Y7 parts
I registered on this site a few years ago but I forgot my password, my other name was StGeorgeHB. I am also a mod on superhonda.com under this current name (40_Below).
Anyways I have a d16y8 head from a 97 Civic EX with about 99k. It will probably need a helicoil in the #1 cylinder. The spark plug threads in tight, but the threads are a little torn up. Also the plastic on the Vtec oil pressure sensor is broken. Comes with Vtec solenoid, valves, springs, rocker assy, and LMAs, and hardware, but the valves from Cyl #1 are taken out and in a baggie. I also have the valve cover if you want it. I DON"T have the intake manifold. Also have the following, prices exclude shipping. Pics available upon request. D16y8 Cam $20 D16y7 rods/Pistons, good shape, $30 D16y7 oil pan $25 D16y7 Crank good shape, $25 D16y7 bare block $40 will ship for probably $25-$40 Spare MAP, TPS, IAC, PCS, CPS, $15 each D16y7 intake manifold $10 T-stat housing $5 T-belt tensioner, $5 D16 water pump (from 00 lx) mint cond. with under 40k, $25 D16y7 upper and lower timing belt cover, a little dirty but no cracks, $15 99-00 CX/DX/LX exhaust manifold, new style that doesn't crack, has both O2 sensors, has a little surface rust, $25 Drivers side motor mount, (part that bolts to engine only) $10 96-00 Dipstick $15 Cheap shipping too! Pic of head http://www.superhonda.com/photopost/...1/DSC03211.JPG http://www.superhonda.com/photopost/...1/DSC03213.JPG http://www.superhonda.com/photopost/...1/DSC03214.JPG http://www.superhonda.com/photopost/...1/DSC03215.JPG Any questions email me! Thanks. |
