Engines Gsr Turbo Ls/vtec Block B16 Sleeved B18 S2000 Look !@!
NO EBAY LINKS!
GO HERE FOR PICS -------->http://pictures.sprintpcs.com/share....2y5kUK3h1kzU3U S2000 COMPLETE ENGINE (BLOCK AND HEAD) !! LESS THAN 20K MILES. NO TRANSMISSION AVAILABLE! BLOCK WILL NEED A BORE, HONE AND CLEAN DUE TO A SCRATCH ON THE WALL OF ONE CYLINDER. CRANK, RODS AND PISTONS ARE 100%. BLOCK HAS NEVER BEEN DISASSEMBLED. HEAD IS IN PERFECT CONDITION 100% COMPLETE WITH ALL CAM CAPS, CAMSHAFTS, VALVES, RETAINERS, SPRINGS, ETC....OIL COOLER WATER PUMP, OIL PAN, EVERYTHING YOU SEE IN THE PICS. MOTOR WAS RUNNING WHEN TAKEN OUT OF CAR. PLEASE ASK ALL QUESTIONS. AUCTION INCLUDES EVERYTHING FROM OIL PAN UP, NO VALVE COVER OR INTAKE MANIFOLD! ASKING 2800 PICKED UP IN NJ/NY/PA/CT/DL AREA WILLING TO MAKE DEAL ASAP. CALL 609-954-8466 CHECK OUT OTHER ENGINES I HAVE FOR SALE:: 1. COMPLETE 1995 GSR TURBO SHORT BLOCK, 81MM BORE, NEW 9.5:1 TO 9.8:1 JE PISTONS , NEW H-BEAM EAGLE RODS, NEW ARP ROD BOLTS, NEW GASKETS, NEW KING RACE BEARINGS, NEW SEALS, NEW VTEC OIL PUMP, NEW VTEC WATER PUMP. INCLUDES PICK-UP TRAY AND OIL PAN..14-16 LBS BOOST. . $1500 2. FIRST BLOCK IN THE PICS 1993 B18A BARE TURBO BLOCK SLEEVED AND PINNED 84.5mm BORE +1mm MORE. RAGE BLOCK GUARD. NEW VTEC OIL PUMP, WATER PUMP, NO CRANK RODS PISTONS $1000. 3. 2000 GSR COMPLETE SHORT BLOCK STR BLOCK GUARD 82MM OVERBORE , JDM TYPE R PISTONS, NEW RINGS, NEW BEARINGS, NEW VTEC OIL PUMP, NEW VTEC WATER PUMP, NEW SEALS, GASKETS, ETC.... $1300 OBO 4. COMING SOON: LS/VTEC BLOCK 1996 B18B1. 81MM BORE, NEW JDM TYPE R PISTONS AND RINGS, SERVICED RODS, ARP ROD BOLTS, NEW KING RACE BEARINGS, NEW SEALS, GASKETS, ETC.. $1300 5. JDM B16 HEAD, PORT AND POLISH ON INTAKE AND EXHAUST, NEW REV STAINLESS RACING VALVES, NEW TITANIUM RETAINERS, NEW TYPE R VALVE SPRINGS, NEW VALVE SEALS. VTEC SELENOID, POLISHED VALVE COVER, GSR CAMS AND GEARS. COOLANT PASSAGE, INTAKE MANIFOLD, $800 B-SERIES VTEC SKUNK2 STAGE2 CAMS WITH SILVER AEM GEARS $500 6. 2000 S2000 F20C1 LONG BLOCK. NEEDS MACHINING AND NEW OVERSIZE PISTONS, 15K MILES, INCLUDES HEAD AND CAMS, BLOCK CRANK AND RODS ALL 100%, TIMING CHAIN, OIL COOLER, OIL PUMP, WATER PUMP, ALUMINUM PAN. NO VALVE COVER, OR TRANS. CONTACT ME FOR MORE INFO. $3000obo 2000 CIVIC SI B16 BLOCK, RUNNING CONDITION $500 2 2000 CIVIC SI BARE BLOCKS, BOTH WITH CRANKS $200 EACH ALL PRICES ARE PICK UP IN NJ/NY/PA/DL/CT AREA. CALL ME AT 609-954-8466 THANK YOU DV |
