h23a1 stuff/h22 IM,TB/f22a1 head, stuff
Old Oct 22, 2004 | 09:11 PM
Losimus's Avatar
Losimus
Default h23a1 stuff/h22 IM,TB/f22a1 head, stuff
okay...left over parts from my project...
h23a1 valve cover - $45 + shipping
2 h23a1 fuel rails (the banjo fitting is on the righ side if you're looking at the front of the engine) - $15 shipped (each)
h23a1 semi-complete block with about 75,xxx miles (only missing bottom main caps and oil journal/girdle...but can use any f/h series...must be machined to fit, i was quoted $125) - $150 PREFER NOT to ship, but will at buyer's expense
h22 (p13 stamped) CLEAN intake manifold (sensor on side is smashed, but you can use your stock manifold's sensor, NO fuel rail/injectors) - $80 + shipping
h22 throttle body (no tps?...the sensor on the side) $30 + shipping
**OR you buy the IM & TB for $100 + shipping
f22a1 COMPLETE head with valve cover, ran strong when pulled...124,xxx miles - $100 plus shipping
**have timing belt and balancer shaft belt...no more then 2000 miles on them, will add for $20 or you can purchase seperate for $30 shipped
f22a1 (LX) header and downpipe...with heatshield (has normal dents in downpipe from being lowered, but flowed good) - $25 + shipping
internal coil distributor that will fit the f22a1 head (i believe 90-91's use this...don't quote me on this though!) - $70 + shipping
that's it for now...might have some more after i get this tuned and running.
will have pics up SOON
Old Oct 26, 2004 | 08:14 PM
Losimus's Avatar
Losimus
bump...
one fuel rail and throttle body are pending sales
Old Oct 27, 2004 | 08:10 PM
Losimus's Avatar
Losimus
okay, f22 head/distributor/belts are temporarily NOT for sale
Old Oct 28, 2004 | 09:04 PM
Losimus's Avatar
Losimus
here are some pics:
h23a1 valve cover
h23a1 block
h23a1 bottom of crank (missing main caps & oil girdle/journal)
h23a1 block side (missing timing belt gear & tensioner)
h23a1 fuel rails
h22 intake man. & throttle body
h22 P13 stamp in intake manifold
the cleanlisness of the intake manifold - 1
- 2
h22 throttle body
Old Nov 4, 2004 | 05:47 PM
Losimus's Avatar
Losimus
alright...up again.
have some new things...
90-93 front driver and passanger side window regulator motors (considerable use, but worked fine when pulled to replace the broken assemblies - bars that move window up and down) - $20 EA or $30 for BOTH
90-93 grey cloth front and back seats, NO rips or burns (from a 91 accord with 92 seatbelt locks, so to make fit in 90-91 you need to reuse your auto seatbelt pods)...they have some overspray from my old car (red...so they look pinkish...i can get them clean though, just have no time.) - $ make offers, i will let you know final price when i get a shipping quote
h23a1 complete milled (i believe it's milled 0.030, not sure...but it's milled by a profesional shop ) head with bent valves, i have replacement h23a1 valves and guides that i will through in...you just need to get them grinded and seated to fit the head. the valve cover that comes with this one is sandblasted and i polished it (silverish) - $125
or you can buy the h23a1 slightly incomplete block and the head for $250 PICK-UP ONLY
Old Nov 6, 2004 | 01:17 PM
sleepersol's Avatar
sleepersol
Hey you wouldn't have the Alternator bracket from either of the H series blocks do you. If so let me know and how much you want for it shipped to 08876. Thanks
Old Nov 6, 2004 | 09:18 PM
Losimus's Avatar
Losimus
no i do not sir...only what i have posted here
Old Nov 8, 2004 | 07:37 AM
gothonda's Avatar
gothonda
hey if i arrange for the block to be picked up would that work? i have an h23 with a rod knock and ill just use those parts to fix the one you have, that would work, right?
Old Nov 8, 2004 | 08:06 PM
Losimus's Avatar
Losimus
hey, if you are serious, PM me or email me (redaccwitah0ttie@aol.com) and i will give you my # so we can arrange a pick up.
and yes, you can use your parts, but from what i was told, you will still have to get those parts machined to match up...but like i said, it's fairly cheap ($125 is what i was quoted)
lemme know,
carlos
Old Nov 8, 2004 | 08:07 PM
Losimus's Avatar
Losimus
H23A1 fuel rail is SOLD...one fuel rail left
H23A1 block is still PENDING
h22a (p13) throttle body is back on the market, as well as the H23A1 valve cover
ALSO...for sale P39 ecu (jdm f22b DOHC ecu)...this is good for those with h23a1 swaps and don't want to run a knock sensor pin - $75 + shipping
