F/S: T3/T04B Turbo, V-AFC, 3" Carsound Cat, Misc D16Y8/B18B Stuff
Old Jul 30, 2004 | 11:37 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Default F/S: T3/T04B Turbo, V-AFC, 3" Carsound Cat, Misc D16Y8/B18B Stuff
Blue Megan Racing H-Brace for 92-00 Civics - Pretty much brand new, installed once then removed because of clearance issues with my cat, brace fits very snug(had to muscle it in place to get all the bolts in), ground clearance is bit on the low side, looking to get back what I paid for it, $50shipped
99-00 Si OEM Exhaust - Stock 99-00 Si coupe exhaust, should fit 92-00 EX/Si coupe/4dr and 92-95 DX/LX coupe/4dr. B-pipe was extended about 1" because it didn't reach my LS cat, but when I got my A'PEXi WS II, that thing bolted right on and is meant for the applications I listed, so the Si should fit as well. Exhaust is in great condition. Does not come with a tip. I really don't want to ship this thing for obvious reasons. $100 obo
D16Y8 starter motor - off a 97 EX MT, $50
D16Y8 head - valvejob, resurface, hot-tank performed ~1000 miles ago; cam has a chunk missing from the distributor end(it still works fine, but you'd probably want a new one); has extended studs on intake side for Hondata gasket; small grooves in cam journals from when I lost oil pressure(probably needs an allign-hone); does not come with VTEC solenoid/pressure switch, valvecover, or distributor, make an offer
D16Y8 Shift Linkage - comes with poly ES bushings, $30
D16Y8 oil pump - ~1000 miles on it, $30
D16Y8 internals - complete internals from my 97 shortblock, #3 piston has cracked ringlands, make me an offer
D16Y8 backup light switch - $15
D16Y8/B18B engine mounts - D16Y8 AC mount, front tranny mount, upper tranny mount(on chassis), rear chassis mount, rear tranny bracket; LS front torque mounts(on chassis); make an offer an any or all
OEM Rear LCA's - fit 96-00 Civics, $40
OEM springs - fit 92-00 Civics and 94-up Integras, $40
OEM Civic shifter arm - $15
OEM Civic radiator fan - $20
OEM LS shifter arm - $15 SOLD
98 LS power steering pump, pulley, belt(not pictured because I have several belts lying around and I don't know which one it is), bracket - 60k miles, $50
98 LS clutch disc, pressure plate - 60k miles, good amount of meat left, $40
98 LS flywheel - 60k miles, good condition, $40
98 LS fuel pump - 60k miles, make an offer
98 LS intake manifold bracket - make an offer
OBD-II injector clips - make an offer
Hydro clutch slave cylinder - comes with Integra softline and short hardline, $30
________________
Buyers pay shipping costs on all items, unless otherwise noted.
All parts listed are from a 97 Civic EX or 98 Integra LS, unless otherwise noted.
Email me(Chris) at inspyral@aol.com
I'm in San Jose, Cali.
Old Jul 31, 2004 | 01:21 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
w00t!
Old Aug 9, 2004 | 12:11 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
o.O
Old Aug 9, 2004 | 12:14 PM
ludermark's Avatar
ludermark
150 for the vafc
Old Aug 14, 2004 | 02:50 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
(ˆ-ˆ)y
Old Sep 3, 2004 | 01:47 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
O.o
Old Sep 6, 2004 | 05:43 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Old Sep 11, 2004 | 12:26 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
