Honda Aftermarket Parts & Upgrades - July 2008 Adult Toys
http://images.hondatuningmagazine.co...heel+front.jpgRonJon Sport DT-3 Wheel Keeping with the company philosophy-remain Honda and Acura exclusive-RonJon Sport Design has answered the many requests to bring back its original Devotion wheel. This time, however, it's higher quality with lower cost, when compared to the rest of the industry's three-piece offerings. Reincarnated with a new soul, large diameters, and an amazing new finish, the DT-3 is built for the most discerning enthusiast. The DT-3 features a true three-piece construction and the looks to go with it. The DT-3 also features a low-pressure cast center and a spun forged anodized inner and chrome outer lip. The standard center finish is liquid graphite with a clear powdercoated, diamond-cut, mirror-polished face. Its 30 rivets are even chrome-plated and the valve stems are hidden. The DT-3 also features perfect offsets, hub centric centerbores, and TPMS compatibility. Sizes range from 19 inch with a 1.75-inch lip, to 20 inch with a fat 3-inch lip, but quantities will be limited. www.ronjonwheels.com 13.5-pound Dry Cell Battery That's right, the engineers at Performance Distributors have developed the Dyna-Batt, the newest lightweight, dry cell battery. Lighten up any Honda or Acura by removing the stock 40-pound battery and dropping in a Dyna-Batt. Technology advancements utilized in the Dyna-Batt allow this small battery to crank any Honda engine with ease thanks to low internal resistance and fast current flow. Similar to an ignition system that performs best with low-resistance plug wires, charging systems perform best with low-resistance batteries. Dyna-Batt's dry cell design means there are no liquids or gels, no acids to leak if the case is accidentally cracked, and if you're storing your vehicle for the winter, you'll be glad to know that the Dyna-Batt has an excellent storage life and recharges quickly. The Dyna-Batt measures in at 7 inches long, 3 inches wide, and 6.5 inches tall. www.performancedistributors.com NOS Launcher Nitrous Controller Nitrous Oxide Systems' new Launcher Nitrous Controller is arguably the most sophisticated controller of its kind, eliminating the need for dials, switches, relays, and chips while combining all the functions nitrous users need into a single easy-to-use controller. The controller is available in three configurations: controller only, controller with 3.5-inch LCD touchscreen, and the Launcher with handheld tuner. The Launcher can be programmed to independently control two nitrous stages but, with the addition of two more slave stages, a total of four stages are possible. Each stage can be programmed as a linear or non-linear curve or by individually adjusting 20 separate points. The Launcher is equipped with an SD memory card slot for data logging, saving track data, changing weather conditions, or lane choices. Additional features include First gear lockout, integrated TPS, programmable activation inputs, an internal MAP sensor, solenoid control channels, wideband rich or lean nitrous cutoff, and time- or MAP-based delivery methods, as well as several safety functions. www.nosnitrous.com. Mishimoto Temp-monitoring Radiator Caps Mishimoto's staff of avid racing enthusiasts understands exactly what drivers are looking for in parts and, as such, is proud to announce the release of its built-in temperature gauge radiator caps. Mishimoto's radiator caps are designed to provide accurate coolant temperature readings at the radiator neck. Each cap comes with a built-in calibrated gauge to maximize accuracy and simplify temperature measurements. Mishimoto caps are designed for most import vehicles, including most Hondas and Acuras, and retail for $65. www.mishimoto.com S2000 Titanium Strut Tower Brace GT Design titanium products from Go Tuning Unlimited-like its S2000 front strut tower brace-are made of the highest quality 6A14V-grade titanium alloy for superior strength and durability. Keep an eye on Go Tuning because a number of exciting titanium products are currently being released. www.gotuning.com AFe Stage 2 '07-'08 Fit Intake Kit Advanced FLOW engineering (aFe) is pleased to announce the release of its Stage 2 air intake system designed for the 1.5-liter '07-'08 Fit. The aFe Stage 2 intake utilizes specially designed roto-molded plastic tubes designed to maximize air velocity and improve horsepower, torque, and throttle response, and the durable 18-gauge powdercoated heat shield blocks out unwanted engine heat. Kits are available with the patented Pro-5R filter, utilizing five layers of progressive cotton media that produce excellent filtration and maximum flow, or the brand-new Pro-Dry S filter that uses a synthetic media and requires no oil to recharge. In recent testing, the Pro-5R filter produced 7 hp and 5 lb-ft of torque with a 104 percent airflow increase. www.afepower.com Password:JDM Billet Aluminum Mini Battery Mount If you're the kind of car enthusiast who appreciates the finest products the automotive industry has to offer then take a look at the all-new Password:JDM billet aluminum battery mount. The mount allows 14.5-pound Odyssey 680 and 680MJ dry cell batteries to fit into any '92-'95 Civic's or '94-'01 Integra's stock battery location. Constructed from black anodized 6061-T6 billet aluminum, the Password:JDM mount is corrosion resistant, and will look great for years to come. The recessed bottom tray locks the battery in place, ensuring it won't move or slip out of place. To add the Password:JDM trademark finishing touch, the top and bottom mounting plates feature laser-etched Password:JDM "P" logos. The kit won't just allow for some serious weight savings but will also clean up that engine bay. Password:JDM's battery mount kit retails for $109.99. www.passwordjdm.com Mothers PowerBall 4Paint Mothers' new PowerBall 4Paint works with any variable speed drill for unmatched coverage and efficiency. Its soft, pliable design makes short work of contoured edges, curves, and other hard-to-reach areas, like door handles, spoilers, and curved, aerodynamic bumpers. Simply attach the PowerBall 4Paint to any drill, position the crown of the ball upward, and pour a small amount of your favorite Mothers polish, glaze, wax, or one-step cleaner wax onto the foam. Set your drill speed to low and rest the ball on the paint's surface. Using the weight of the drill, start slowly and the PowerBall 4Paint glides gently and almost effortlessly across the finish. Let the wax product haze and remove as directed. The end result is more thorough and even in coverage in less time and with less effort than applying by hand. The PowerBall is also washable, reusable, and reversible. Kits include the polishing tool, storage case, and a 4-ounce bottle of FX Synwax. www.mothers.com MagnaFlow 1.8-Liter '06-'07 Civic Exhaust MagnaFlow has developed a complete stainless steel cat-back exhaust system for the '06 and up DX, LX, and EX Honda Civic coupe. Its straight-through muffler design coupled with mandrel-bent tubing reduces backpressure, allowing for performance gains that carry across the entire powerband. This stainless steel bolt-on cat-back begins with 2.25-inch mandrel-bent tubing, flowing through a 6-inch round polished muffler and then through a 5-inch round polished muffler with a polished double-wall, angle-cut 4-inch tip. MagnaFlow designed the system for a smooth, deep tone with little to no resonance for driver comfort but with a defiant roar on throttle. To hear high-quality sound clips of MagnaFlow's Civic exhaust visit their Web site: www.magnaflow.com Photo Gallery: Honda Aftermarket Parts & Upgrades - July 2008 Adult Toys - Honda Tuning Magazine http://images.hondatuningmagazine.co...heel+front.jpghttp://images.hondatuningmagazine.co...attery+top.jpghttp://images.hondatuningmagazine.co...ss_and_exu.jpghttp://images.hondatuningmagazine.co...iator_caps.jpghttp://images.hondatuningmagazine.co...ower_brace.jpg Read More | Digg It | Add to del.icio.us More... |
