changing brake light 05 CR-V
Bored Enthusiast
Can some one please explain to me how to change the right brake light on a 05 Honda CR-V. When you open up the rear latch there are 2 8mm bolts that i see need to be removed to removed the light console, but it doesn't seem to want to come loose after those 2 bolts are removed. Is there a third bolt underneath the rear bumper? Or do you remove the inside paneling for access to replace the light?
