Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
97 CRV Help
Old Dec 12, 2006 | 04:06 PM
K Saint's Avatar
K Saint
Default 97 CRV Help
I have two problems I need help with.
1. Where is the wiring harness connection located for wiring lights for a hitch?
2. I have a problem with the driver side door lock. It will only let me open it with the key sometimes. I'm getting tired of opening the passenger side and having to crawl over the seat to unlock it!! Is there something I can fix or replace? I am considering installing keyless entry. Would that work with the door not unlocking?
Thanks for your help!
Old Dec 13, 2006 | 06:16 PM
Fuse's Avatar
Fuse
1.did you have a hitch installed?if not the wiring will not be there.If you do have a honda hitch it should be zip tied to the hitch.
2.Dose your lock cylinder turn?if it is the rod from you cylinder to you latch is loose or you have a bad lock cylinder.
Key less entry would help but not fix the problem.
Old Dec 14, 2006 | 02:29 AM
m735is's Avatar
m735is
I just switched to the unused extra key for my wifes drivers door. It works great with that key, but sometimes hard to lock and unlock with the well used one that I carry.
