Oxygen sensors
Old Dec 30, 2002 | 05:20 AM
1911mojo's Avatar
1911mojo
Default Oxygen sensors
Has anyone had to have their oxygen sensors changed yet? I have to have both the front and rear drivers side changed and would like to do it myself, but cant find any info on it. The dealership is going to run me about $170 in labor and $232\each for the sensors. I can get universal sensor from Auto Zone for $70.
Old Jan 26, 2003 | 12:00 AM
Juiced_RL's Avatar
Juiced_RL
Default I had to get mine replaced!
I had mine done but it was still under warranty
Old Feb 2, 2003 | 05:59 PM
phughes137's Avatar
phughes137
My check engine light came on 6 months ago and the code said I needed to replace one of the O2 sensors. I used a bottle of engine/fuel injector cleaner and it cleaned the deposits off of the O2 sensor so I didn't have to replace it. Been running fine ever since (12k miles).
BTW the sensors are supposed to last 100K miles and sometimes the error can be caused by the heater not working correctly. The heater is supposed to allow the sensor to work right after starting the engine before the engine has had a chance to heat up. If you have noticed a decline in performance then you probably don't need to replace it as it regulates the oxygen mixture for proper fuel combustion.
Old Feb 2, 2003 | 06:48 PM
Shoofly's Avatar
Shoofly
The front O2 sensors aren't too bad to replace, but the rear ones you might have trouble if you cant get underneath the car. Other than that its all in what kind of tools you have. Autozone and other similar parts stores may lend you the proper tools to remove and install new O2 sensors. Good Luck
Shoofly
Old Feb 3, 2003 | 06:06 AM
1911mojo's Avatar
1911mojo
Default O2 Sensors
Thanks for the replies everyone.....Where exactly are the sensors? If I can get to them, I would rather do it myself and I heard they are pretty easy to replace once you are there.
Old Feb 3, 2003 | 01:06 PM
BigRi's Avatar
BigRi
The RL has an extended emissions warranty of 14 years or up to 150,000 miles. I think the 02 sensors are included in that warranty, you have to go to a new Acura dealer to find out, not one of those used Acura/Infiniti dealers. Check it out, it saved me a lot of money.
