Fuel pump relay
Old Jul 2, 2008 | 09:31 AM
Joe Gonzalez's Avatar
Joe Gonzalez
Default Fuel pump relay
Where is the fuel pump relay on a 1991 legend sedan?
Old Jul 2, 2008 | 08:59 PM
ari_one's Avatar
ari_one
It is called the "main relay" and is located under the drivers side lower dash. Common problem on them is poor solder, you can open them up and re-solder to fix. It is pretty easy to see the cracks, normally they are on one or more of the solder points in the middle of the board. Temporarily sometimes you can give the lower dash a whack with an open hand and it sometimes gets the connection back enough to start and run for a little while.
Old Jul 8, 2008 | 06:26 PM
af1racing's Avatar
af1racing
Shaking it violently will also cause the car to start. I would buy a new one though.
Old Aug 17, 2008 | 07:24 PM
lance50's Avatar
lance50
i fixed my relay by resoldering all the joints on the relay. solder flux helps and i have not had a problem for the past eight months, after exreriencing regularly the no starting problem when car has been sitting in sun all day.
Old Sep 4, 2008 | 08:30 AM
saassguy's Avatar
saassguy
my 1996 acura 3.5 rl shutoff at the stop sign and would not start. where is the fuel relay located?
