mfraner |
05-08-2008 03:49 PM |
Bought 1 from a Dealer. They want $8.00 & change each & they told me they wont replace just 1. When they replace them it's all or none. After replacing one I believe them. When I reassembled my Instrument Cluster there were 6 more out just from handling it. The one I bought from them came with the socket like they were permanently attached but although they are tight I was able to remove them without breaking the sockets. went to Autozone & bought 12 bulbs like Toyota uses for $15.00 Total. The bulb is slightly smaller but same base. They will work fine, mine did. They are not easy to replace but well worth saving 300 plus dollars the Dealer wants to do the job. You have to remove parts of the console and center part of dash where Radio & Heater controls are located to get the Instrument Cluster out. Then 2 circuit boards are stacked together on back side of Inst. Cl. They will have to be removed to access the bulbs.
