Adding vtec to 1996 ls
Originally posted by Beachballer83
i want revs higher than 7 grand, do i start working on internals and then figure out which turbo
The rod/stroke ratio's of b18b/a LS motors and b20b/z motors arent best suited for high revving. They are more known for their robust torque characteristics. The blocks arent casted as beefy (not as much webbing, thinner cylinder walls) as the other b-series vtec blocks as well. By the time you get your motor to safely rev high (oil squirters, oil pump, pistons, rods, studs, girdle, etc from other vtec blocks), you would have spent enough money to have just upgraded to a complete GSR block and tranny, assuming you do your pricing research and shop comparisons. Done correctly though (emphasis on correctly), an LS/Vtec or B20/Vtec can prove itself as a very potent and reliable setup.
DB Squad
Integra Forum Moderator
DB Squad
Oh yeah by the way, if you decide to use your stock LS tranny with an LS/vtec setup, have fun being slow. A GSR tranny would be suited better for the vtec powerband without being too short (i.e. b16 - 4k plus rpm at freeway speed) for freeway cruising.
DB Squad
DB Squad
