exhaust rattle at certain rpms
no one give yur hopes up tho, i was so excited to replace the header and remove all that garbage expecting the embarassment to stop...man was i pissed to find the same noise...im happy with it now tho, it makes it more of a sleeper
i bet the 1400 rpm is the gaskets, bolts and springs between the exhaust pipes because i had the same **** on my accord at 1800. honda sold me a "buzz kit" consisting of new springs and gaskets and bolts which fixed the problem, and acura has the same "buzz kit" for the integra. that will *probably* fix the 1400 (i think, and i hope) but the 3k-4k thing really pisses me off. how EXACTLY did you remove the heat shields? did you have a lift? what tools?
the 3000 rpm buzz is probably from the heatshield right after the cat (but before the resonator) attached to the underside of the car. just take out the 2 10mm bolts holding it on, & you should be good.....well at least i was, anyway.
Originally posted by drdavidge
where are the 2 bolts? how can i get to them easily?
The heat shields are most likely not your problem. I used to have a 95 gsr and the header internally has something that comes loose and can't be fixed. Best option is just to get a new header. I went with the dc sports 421 ceramic header, but if you plan to do some serious engine work later go with the JDM 41 series.
