Question about front seats....
Old Jul 6, 2003 | 08:48 PM
VFR750F's Avatar
VFR750F
Default Question about front seats....
Does anyone know if the front seats from a 2002 RSX will directly fit (straight bolt-on, without any modiffications) into a 1994 RS?
Cheers, V.
Old Jul 7, 2003 | 07:19 AM
Spec R's Avatar
Spec R
the holes will only line up on 2 or 3 of the mounting points...i'm not positive though. I do know that there is modification needed for sure though. they will also sit VERY high in your car. i've sat in a EG hatchback with the new Si seats, and my head hit the roof, just sitting down, not while driving. I'm 6 feet tall.
DB Squad
Integra Forum Moderator
Old Jul 7, 2003 | 10:00 AM
VFR750F's Avatar
VFR750F
Thanx Spec R.......
One more thing...Do you or anyone else happen to know what years and models will fit my '94 Integra RS Coupe as a direct bolt-on?
The foam in my drivers' seat is getting rotten I guess, and the seat had become rather uncomfy....
Thanx y'all, V.
Old Jul 7, 2003 | 11:48 AM
gsr4d95's Avatar
gsr4d95
all integra seats will fit in your car, as well as civic and del sol seats. You might be able to take the rails off your seat and attach them to the RSX seats.
Old Jul 7, 2003 | 11:54 AM
Snoopy's Avatar
Snoopy
been there done that
del sol seats are nice. you sit a little lower but they are very comfy and supportive. :thumbup:
Old Jul 7, 2003 | 11:56 AM
Spec R's Avatar
Spec R
That same friend with the EG tried that, it didnt work.
DB Squad
Old Jul 7, 2003 | 12:03 PM
gsr4d95's Avatar
gsr4d95
tried swaping the brackets? and that didn't work? you can try and get custom brackets for the RSX Seats.
Old Jul 7, 2003 | 03:42 PM
airon's Avatar
airon
AARONNOJIMA.COM
the only bolt in seat for integs are 92-95 civics and other 94-01 integras
to put in del sol seats or 96-00 civic seats you need to swap rails
for s2k, new si, or rsx seats to fit you gotta modify and pound the crap out of the rails, its been done but exact modifications i dont know
also like said all newer seats sit higher up then your integ seats, so keep that in mind, also on the seats with side air bags will be useless
