Clutch SQUEAKS
Old Jul 6, 2003 | 02:27 AM
Turbonium's Avatar
Turbonium
Default Clutch SQUEAKS
when i press the cluth in or let it out, it makes a minor squeak noise and feels rough(kinda jagged feel) during the middle of pressing it down to the floor. i was thinking that maybe i should lube it but where, and would that fix the problem? my car has 40k on it and its a 01' integ. anybody have suggestions?
Old Jul 6, 2003 | 07:23 AM
pomansouth's Avatar
pomansouth
yeah its your throw out bearing. the part isnt expensive but the labor is. if your hold your foot on the clutchat stop lights then this may be a reason for it to be worn so early. you should never hold the clutch in unless you need to shift.
Old Jul 6, 2003 | 09:40 AM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
Unfortunately, it does sound like the throw-out bearing. This happened on my dad's Toyota Tacoma, but the mechanism that adjusts the spring-tension in the pedal was just out uf lube. Since I don't think the Teg has this, I don't know what else it could be...
Old Jul 6, 2003 | 10:05 AM
dubcac's Avatar
dubcac
I
It's your throwout bearing. Mine has been doing the same thing for a while, and I'm not dropping the tranny just to replace a stupid bearing. If I get a different block or tranny, then I'll do it...but until then, it gets driven like it is. It's been squeaking for a long time, and it's still fully operational.
Old Jul 6, 2003 | 11:19 AM
LT's Avatar
LT
The deer had to die!
mine squeaks on and off, i believe either 1) the slave cylinder needs a lubing (not hard), 2) the push rod that goes from pedal through firewall needs lubing, 3) the throw-out bearing is starting to go.
Old Jul 6, 2003 | 02:43 PM
Turbonium's Avatar
Turbonium
yeh i thought it was also #2 from wat LT6916 said, but dubster u say that u need to drop a tranny to change the bearing?
how much and wat would i need to go about to fix this problem.
Old Jul 6, 2003 | 09:11 PM
tub_sephiroth's Avatar
tub_sephiroth
I had this problem too. I took it into the dealer. First, they replaced the master clutch cylinder and lubed some kind of fork. This didn't stop the squeaking so I had to bring it in again. Sure enough, it was the throwout bearing. They replaced it, gave me a new clutch assembly and everthing under warranty. This dealership is okay with me. :thumbup:
