JDM front end questions
Old Jul 3, 2003 | 06:42 PM
AcTegGS's Avatar
AcTegGS
Default JDM front end questions
If I change to a JDM ITR front end(fiberglass) and want to add a lip, will I need a lip especially for the conversion or will any lip designed for the US Integra fit as well? And do fog lights come on the JDM headlamps(I know USDM has highs and lows as the four lights)? So I will need new wires for that and a switch if I ever want to shut them off(doubtful)? I will probably have more questions as I delve deeper into the JDM world!
DP
File Type: jpg
Old Jul 3, 2003 | 08:42 PM
veen's Avatar
veen
Seņor Member
www.passwordjdm.com they have them and can tell you what you need to know, whats that image about?
Old Jul 3, 2003 | 09:02 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Its a band veen
Old Jul 3, 2003 | 09:17 PM
Snoopy's Avatar
Snoopy
been there done that
you need a lip for the conversion
Old Jul 4, 2003 | 08:09 PM
Ferio Man's Avatar
Ferio Man
werd
Old Jul 13, 2003 | 07:42 PM
del Samo's Avatar
del Samo
oh man is veen retarded, what a sheltered little girl
Old Jul 24, 2003 | 01:04 AM
kabob's Avatar
kabob
The foglights are also an OEM option so you will have to buy them seperately. They're yellow to match the inner bulb on the headlights (what do they use that for?) and you'll need to make sure that if you get a pair, it comes with a wiring harness and mounting brackets (or fab your own) and there is an OE Honda foglight switch you can purchase. It goes where those the left side round plastic covers opposite the dimmer switch below your gauges.
Old Jul 24, 2003 | 10:41 AM
veen's Avatar
veen
Seņor Member
and you wonder why no1 calls you
Old Jul 27, 2003 | 04:35 PM
AcTegGS's Avatar
AcTegGS
So where would I go about getting the entire fog light assembly since it doesnt come with the conversion itself? I looked at passwordJDM and they only have the switch, and I don't care if they're on constantly(or at least whenever the headlights themselves are on)! So I need to get the bulbs, harnesses, and whatever I need to wire to get them to come on with my regular beams? If so, where can I achieve this JDM feat?
DP
Old Jul 27, 2003 | 05:07 PM
forum95's Avatar
forum95
I'm Cooler than You
fiberglass is gay get the OEM all metal one.
