4 lug vs 5 lug
Old Jun 17, 2003 | 05:36 PM
twin3037's Avatar
twin3037
Default 4 lug vs 5 lug
all the tech people out there does the 5 lug suspension system of the type r havean advatage over the 4 lug system used on the gsr?
Old Jun 18, 2003 | 02:16 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Default Re: 4 lug vs 5 lug
ITR has bigger brakes, i think 11" in front and 10" in the back.
Old Jun 18, 2003 | 08:53 PM
twin3037's Avatar
twin3037
i can replace the brakes tho
Old Jun 19, 2003 | 10:00 AM
00R101's Avatar
00R101
ITR rear suspension is different than GSR. It uses a split lower control arm with an internal shock mount. It resists flex much better. Also ITR uses larger hubs and bearings - big advantage in longevity on the track.
Finally having 5 rather than 4 lugs is a strength thing as well.
If I were you I would decide what I wanted to do to make my car better in performance and not try to turn it into a Type R.
Old Jun 19, 2003 | 11:39 AM
94civicEX's Avatar
94civicEX
I got worms.
What about the 97 Spec R's with 4-lug?
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 19, 2003 | 02:27 PM
Daniel's Avatar
Daniel
JDM only, USDM had 5 lug in the US.
Old Jun 19, 2003 | 11:38 PM
Highrpmek's Avatar
Highrpmek
FD3S dreamer
I think he is refering to the size and performance of the Type R 4 lug brakes. I think the 5 lug brakes are bigger, Atleast thats what i've heard. I personnally want to add the ITR 5 lug brake and suspension to my HB. The ITR brakes are more than enough for an Integra and especially a light weight civic hb. Most of the Auto X guys will tell you to just buy good pads and rotors for your ITR brakes and then spend the rest of your money on a good suspension set up. Thats my 2 cents I hope it helps you, Good Luck.
Old Jun 20, 2003 | 09:35 AM
twin3037's Avatar
twin3037
thanks for the input all
